Results 1 to 9 of 9
Thread: Beefing up my 200x
    Mar 2013
    Minnesota
    441
    Beefing up my 200x
    I got my stock 1st gen 1983 200x and im looking to beef it up a bit.
    NO I DON'T WANT A BIGGER ATC, I GOT MY 250R.
    AND NO I DON'T WANT A BIGGER ENGINE.
    What parts do you guy's think i should put/add to it?
    Links from ebay would help also.
    ~~ATC's Currently Owned~~
    1983 Honda 200x - Main ATC
    1985 Honda 200x - Parts Bike
    ~~ATC's Previously Owned~~
    1983 Honda 250R
    1984 Honda 200X
    1979 Honda 110
    1983 Honda 125M
    1984 Honda 200
    1983 Kawasaki klt 200a
    1986 Honda 200s
    ~~Other Toys Owned~~
    2012 Pro R 800
    1993 Polaris Indy 500
    2004 Yamaha 125
    1990 Thunder Kart - 250CC
    2001 Yamaha Blaster - 240kit, aftermarket exhaust, power reeds
    Slidell, LA
    4,738
    Powroll has been down for approximately 5 months and don't know for sure if they are ever coming back. I can't even get a hold of them on the phone. Unfortunately you will have to piece the "kit" together for a complete rebuild. There isn't a one stop shop for all things 200x. All of the parts I used for my rebuild came from Ebay and/or Bike Bandit. Below are some of the parts I used.
    Gasket Kit (I only use Versah as they are within Honda OEM Specs):
    http://www.ebay.com/itm/Honda-1983-1...538392&vxp=mtr
    Bearings:
    You will need to piece these together from bike bandit. Most are readily available except for the 20MM needle bearing that the transmission counter shaft rides on. If you think you need that bearing, contact me when you get to it and I will let you know where I sourced my bearing from
    Cam:
    If you want a better cam but not upgrade your exhaust or airbox go with this one: http://www.webcamshafts.com/pages/at...10_000084.html
    If you want a better cam and you are upgrading your intake, exhaust valves and springs, go with this one (Note, this cam requires that you flash chrome your rockers part number HR-H14): http://www.webcamshafts.com/pages/at...10_000085.html
    Valves / Springs / Retainers:
    Go here; http://www.webcamshafts.com/index_bl...le_search.html
    If you are running the upgraded cam (second link above), then you want the part numbers below
    VC-H2T
    IV-H13
    EV-H14
    Piston: Personally, I get my cylinders mic'd by a machine shop and then I buy the cylinder on the next overbore and finally I have the shop match the cylinder to the new piston. Below I have placed a link to a 10.25:1, 1MM overbore piston. If you just want the shop to bore the cylinder to match and not go through the trouble of mic'ing the cylinder then this one could be for you.
    http://www.ebay.com/itm/Wiseco-Pisto...82d5e3&vxp=mtr
    Have fun!
    Williamstown PA
    5,825
    the easyiest way to make some power is the following
    rebuild motor, have it bored for 10.25:1 wiesco piston. screw powroll, they make high HP which is cool but honestly into todays world not many are going to spend that on small motors to run race gas. Theres a reason the sites down. Stay with weisco who own the market in rebuilding motors.
    3rd buy a new xr200 cam, its a bolt on, has more lift revs more, and a full exhaust, maybe even an XR200 carb. It will feel like a powerful bike but hey be realiable and not cost 2 grand to rebuild the motor.
    theres way more you can do, rebuild shocks, or swap out for 250R suspension but so far im the only one with the master mind know how to get 10" of travel out of a 200x so it feels like a 250R....i can however sell you that technologry if you have money. If you dont focus on the motor and maybe some good tires and shock rebuild.
    May 2013
    Henderson, Tx.
    977
    Fst has a BB/Stroker kit for the 1st gen X. I've talked to Powroll twice in the last two weeks. Had to leave a message both times, but, they called me right back. Far as I know, they are not ditching any of their old kits. I'm going to do their BB for the 350x. But, if all you are looking for is a damn good reliable engine, that makes very good power, do Yeager and oldschool said. Can't beat a good mild build that makes fun power.
    Indiana
    16
    What about an 86 200x? Anyone have suggestions on beefing one up?
    1986 200x
    Sep 2012
    any idea what exhaust will b best
    Mar 2014
    I am getting ready to do a conversion on my 200X's swing arms and set them up like 250R's and a plus 4. It will take me a little work but it will be worth it.
    Mackus84's Avatar
    Mackus84 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2016
    Lakeland, Fl
    427
    Bearings:
    Sorry for bringin back an old post, but ive been looking for this bearing too. The needle bearing. Im thinking its part # 91052-ZV4-003 which is (15X21X12)
    Sep 2014
    Oregon
    591
    Quote Originally Posted by Mackus84 View Post
    Mine is INA NTN HK1512 V2. Stamped right on the bearing.
