Results 1 to 9 of 9
Thread: 86' 250r swinging arm bolt?
    South Wales, U.K.
    525
    I'm sure I was told a 400ex swinging arm bolt is a good replacement?? is this right before I order a new one?
    I had to cut my bolt out!
    If it ain't sideways......what's the point!!
    86' Honda Atc 250R - under restoration
    10' Polaris Outlaw 525s - my XC race quad
    05' ATK 640 "Cannondale" xc racer
    00' Banshee 350
    STL
    3,560
    I cut my 86 bolt out too! With a freaking sawzall l o l . anyways, ya i have a 400ex bolt in mine. maybe 300ex, i forget its been a minute. anyways, i went with a used one for like 25$ shipped on ebay. You may have to find a press to get the pieces out now! I had to
    May 2005
    Southern NH
    1,489
    Make sure you put some lube on the new bolt. Personally I recommend marine lube. That stuff is the best for water and corrosion resistance.
    "I have but one lamp by which my feet are guided, and that is the lamp of experience." -Patrick Henry
    NEW ENGLAND ATC owners please join!:http://www.3wheelerworld.com/group.php?groupid=27
    Blossvale NY
    4,563
    Another solution to prevent the new swingarm bolt from seizing is to replace the conventional swingarm needle bearings with the nylon swingarm bushings sold in the 3ww shop. There is no possible way for the bolt to seize in nylon! I have a set in my 250, and aside from a little bit of squeak that developed after a bit of ride time, I am completely happy with them!
    Unfortunately out of stock at the moment, but here they are... http://shop.3wheelerworld.com/produc...?productid=101
    BTW, I am not the seller of these parts, just a satisfied customer putting in a plug for a great product available right here from the community
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    STL
    3,560
    I have run those bushings as well at last trikefest, very good product.
    O.C., Oregon
    921
    I have a 400ex in my 85r now. Works great and you can't beat $27 vs whatever crazy money the atc250r ones go for now. 400ex bolt FTW!
    1978 ATC70 w/ Piranha 140cc
    2017 YZ 250x- Braap
    South Wales, U.K.
    525
    Thanks i'll order one this week!
    I got my frame back yesterday painted... i'm sick of seeing stock color 250r's so mine isn't!!
    00' Banshee 350
    Aug 2010
    Southern Oregon Coast
    932
    trx450r is also the same. If I remember right it was the cheapest of the 3.
    Miami,Fla.(305)
    808
    x2 - I got the 450R swinger bolt on my R as well- since it was much cheaper. Mine wasnt stuck-just worn badly where
    the bearings ride. I guess thats why it didnt seize.lol
    its appearance is slightly different but length and diameter is the same.
    Previously Owned:
    1985 ATC 250R (261cc)- 38MM PWK QV/AS, VFORCE3, RPM TIMING ADV., FULL DG EXH, CLARKE WHITE TANK, DOUGLAS RED LABELS, PRM NERF BARS, + ALUM. PARTS
    1983 ATC 185S (186cc)- HI COMP., BASSANI HEADER, REAR DISC BRAKE CONV., '86 200X HUBS, ALUM. RIMS, DIRT DEVILS
    1982 ATC 185S (224cc)- PK WELD-ON KIT, PK CLAMPS, PK EXHAUST, SL90 SHOCKS, OIL COOLER, PCCC RIMS
    1981 ATC 185S
    1984 ATC 250R
    1981 ATC 250R
    1983 ATC 110
    1969 HONDA MINI TRAIL 50
    TRIKELESS
