Results 1 to 2 of 2
Thread: HELP....1981 atc 250r bottom rod bearing
    May 2013
    Kansas
    9
    I need help. I don't know how to change the bottom rod bearing on my wheeler. I was riding it and all the sudden it tried to lock up. Thought I blew out a ring in the cylinder and was sure I put scratches all up and down the cylinder. Took it apart and the bottom rod bearing had blew to peices. There were metel shavings getting stuck. Not letting the crank move freely. And I'm wondering if anyone knows how to change that bearing?!?!?
    Blossvale NY
    4,563
    You will need to do a complete engine tear down and remove the crankshaft. Unless you are a machinist with the proper press and jigs, rebuilding a crankshaft is something you will have to have done at a shop.
    The crankshaft must be pressed apart to replace the connecting rod/lower rod bearing. And consequently is must be pressed together, PROPERLY aligned.
    So, since your lower rod bearing failed, you will likely need the crank fully rebuilt as the crank pin is likely to be toast as well.
    Or, you could seek out a new rebuilt crank assembly. Hot Rods has a good reputation. Just need to look and see if they offer cranks for the air cooled R. If so, it's as simple as just replacing the whole crank assembly.
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
