Results 1 to 14 of 14
Thread: ATC 200es - 200x front end swap
    Apr 2013
    Mackay, Australia
    45
    I'm putting a 200x front suspension on a 200es. Problem is that the steering stem is about 1" too short. Is there a steering stem that I can use from another bike?. Or do I have to get the existing stem extended some how. Has anyone got any experience with this challenge?
    Nov 2012
    Waldoboro, maine
    791
    82 250r
    83 Big Red
    85 Auto-x
    If you've done business with me please leave me feedback
    http://www.3wheelerworld.com/showthr...ght=Bren_downe
    Apr 2013
    Mackay, Australia
    45
    Bren_downe, thanks for the post. I cannot see the pictures on the link you posted yet as I'm only just registered. Does the stem simply replace the standard 200x one?. Does it take standard 200es headset bearings?. If "yes" is the answer, then where do I get one ASAP?. Appreciate your referal.
    Nov 2012
    Waldoboro, maine
    791
    Ol Duece is the member who makes and sells them, first you grind the stem off of you 200es lower clamp then make 4 holes in 200es stem, the adapter slides into the stem and you plug weld the holes. The bottom of the pin presses into the 200x lower clamp and your ready to go with the 200es bearings and races.
    82 250r
    83 Big Red
    85 Auto-x
    Nov 2012
    Waldoboro, maine
    791
    http://www.3wheeler.org/vb/showthrea...110&highlight=
    Same pin, same ideas. Get that post count up so you can see the pics!
    82 250r
    83 Big Red
    85 Auto-x
    Nov 2012
    Waldoboro, maine
    791
    http://www.3wheelerworld.com/showthr...0x+tree+on+110
    Found it here, now that I think about you should be able to see the pics even if your a new member.
    82 250r
    83 Big Red
    85 Auto-x
    Apr 2013
    Mackay, Australia
    45
    How do I make contact with Ol duece? I love the concept & wish to buy the adapters. Also which headlight do you recommend for the 200x headset? Another question, what have other people done with the mount for the ignition key, neutral & reverse lights? I've used a "vapour" dash on one of my bikes and that would give me the ability to add a speedo & tachometer which would be cool.
    May 2013
    Cut and Shoot, Texas
    57
    its because as a new guy , your supposed to stay at the kiddy table and not get around the adults for 2 months! Even though your answer is there, you cant have it, your new.
    Quote Originally Posted by hilltj View Post
    The art of custom PowderCoating
    TxPowderCoating.com
    832-818-3905
    May 2013
    57
    its because as a new guy , your supposed to stay at the kiddy table and not get around the adults for 2 months! Even though your answer is there, you cant have it, your new. I think it sucks too
    TxPowderCoating.com
    832-818-3905
    Apr 2013
    Mackay, Australia
    45
    Guys, help! I really need these adapters to continue with my project. Any assistance would be great. Would someone be able to make contact with ol deuce on my behalf? I promise that I'm honorable & trustworthy. I'd appreciate it.
    Nov 2012
    Waldoboro, maine
    791
    Try sending him a PM, should be able to do that as a newby.
    82 250r
    83 Big Red
    85 Auto-x
    Apr 2013
    Mackay, Australia
    45
    Bren_downe, did that now awaiting a response. Cheers
    Nov 2012
    Waldoboro, maine
    791
    Good luck with the build and remember to post pic!
    82 250r
    83 Big Red
    85 Auto-x
    Apr 2013
    Mackay, Australia
    45
    Cheers Bren_downe, thanks for the support. It's all comming together slowly. I've built several project bikes in the past, I know that at times you feel like 2 steps forward & one step back!
