Results 1 to 15 of 16
Thread: Spark plug threads messed up -HELP ME!
    Ashland City, TN
    2,576
    I screwed up my spark plug threads....which is a trailprotrailprotrailprotrailprotrailpro. It's not all the way, only like the last 1/8 of the threads, in the head. What's the best way to go about fixing them? Do they make a special tool for fixing plug threads? It's so bad that when I start to thread the plug it, it starts straight, then changes angles!! Thanks in advance...
    Trikes:
    1973 Honda ATC70-orange!
    (2)1985 ATC70
    1985 Big Red 250
    1985 250R
    May 2002
    Dublin, Georgia
    635
    Crap
    You will need to remove the head to prevent any metal shavings from falling in cylinder. You can try using an tap to retap the threads, if they are beyond this you will have to drill tap and install a helicoil.
    84 ATC200X--Wife rode it once, now I can't get it back.
    84 ATC250R--Trying to find piston for 300R kit.
    85 ATC350X--Project finally under way, slow progress. For pics: http://groups.msn.com/ATCfriends/350xproject.msnw
    84 ATC200S--Freebie from a neighbor, needs topend rebuild and tires.
    Ashland City, TN
    2,576
    That pisses me off. I haven't seen any manuals for this either...it's actually a dirtbike of mine, the good ol TL250, but I posted here because I figured it would get more attention. Welp I think I can figure out how to take it off without too many problems. Better go get to work!
    Trikes:
    (2)1985 ATC70
    1985 Big Red 250
    1985 250R
    May 2002
    Dublin, Georgia
    635
    Unfotunately...
    .. the only safe way to do it is to remove the head. Those metal fillings from using a tap are severely detrimental to the cylinder happiness.
    Ashland City, TN
    2,576
    Welp I did it, and went over to a buddies place who has a tap&die set....ran a tap through it, no good. Somehow, the threads got really fawked up and decided to make a different angle of hole. Now I have to HeloCoil the mofudda. Great.
    Trikes:
    (2)1985 ATC70
    1985 Big Red 250
    1985 250R
    Detroit, MI
    837
    There's a company that makes taps that will catch metal shavings, made specifically for the aluminium heads. If you want the company's name and phone # let me know, I'll dig it up.
    1986 ATC 250R(for sale), 1963 AceCraft boat w/40HP Evinrude, 1981 Arctic Cat El Tigre' 440 L/C, 1992 GMC Safari Van.
    Sep 2003
    El Paso Tx
    1,123
    I dunno about that hemi, When I bought my 185 s plus problems one of which was a stripped spark cork and had to redo it it sure seemed simple and I said to myself: How much filings can this ting make? Its only a mm or so extra. I swept up about 2 tablespoons full of aluminum. Good thing I didn't leave the head on and use the lazy man's grease method recommended by a local mechanic.
    Detroit, MI
    837
    These are taps with a magnet or some method to catch the threads so they dont fall into the engine. It's an automotive application but I'm sure it'll work just fine on these bikes. It was on the back page of Car Craft a month or two ago. They're like $20.00 for a tap but it's worth to keep from having to tear a head off. If goku want's the company name and phone # I'll look it up for him, Car Craft may even have something on their web site about it.
    Sep 2003
    El Paso Tx
    1,123
    try this place: http://www.findarticles.com/cf_dls/m3102/11_119/67320361/p1/article.jhtml--Motor age march 2001
    SE Minnesota
    533
    magnetic tap
    If you buy a magnetic tap to catch the shavings, it wont work on aluminum.
    83 YT 175
    85 ALT 125
    Rittman, Ohio
    6,276
    Re: magnetic tap
    Quote Originally Posted by Dan Tenn
    LOL! I was watching to see how long it would take someone to catch that! Sorry, I dont have a prize!
    Detroit, MI
    837
    The january 2004 Car Craft issue, very last page is the product.
    www.starrproducts.com
    potsdam NY (upstate)
    1,437
    i was going to say if you were talkign about your tri z head i would have sold you one cheap in great shape that i have kicking around
    looking for a TRI-Z 250 to restore at the moment
    LONG LIVE THE 2 STROKES !!!
    Rittman, Ohio
    6,276
    That looks like a great little gadget. It works simply by keeping the hole plugged below where you are cutting, and pulling the shavings out, as you are threading from the inside out.
    Detroit, MI
    837
    seemed like a good product to me . You guys understand now? The best way to understand it is to watch the video.
