Results 1 to 7 of 7
Thread: 85 Honda 250 big red need help
    Jun 2013
    Brockway pa
    I have recently got a 250 big red off a friend from work he hasn't ride it in some time I first off started by trying to clean the carb wasn't happening the jets were both broke so no way to even get them out so I took a carb off my 200 xr that I'm rebuilding it started right up one kick but when I drive it after about a mile or so it shuts down an won't start till it cools down still getting fuel down fall was had no tools to check plug for spark when it died were
    should I start
    Pacific NW
    4,255
    Sounds like you're on the right track.
    I got so aggravated with my tractor, I put a big red carb on it.
    Anyway, do you see gas coming out of the fuel line?
    Might be better to check at the float bowl drain.
    Could be as simple as a gas tank vent.
    Great idea to check for spark when it dies too.
    Without tools, you can just unscrew the sparkplug cap and check for spark
    with the plug wire against the engine.
    See if the plug wire is getting green and corroded where the spark plug cap screws in while you're in there.
    Nipping the last 1/4 inch off that wire may make a difference too.
    Keep us posted.
    Jun 2013
    Brockway pa
    I'm pretty sure it's not the carb cause the bike ran good with it but I didn't think about vent I used to have a 185 s that would pressure lock on me I ended up drilling a hole in the gas cap an threading a small fitting into it to put a small breather on but with this I have a wire coming out of the side case that is about to break off I'm not sure if that Woodlake it die on me or not is the magneto on the break pedal side on this my bike it's on the other side but heads are backwards so I guess it's possible
    Jan 2013
    minnesota
    5,911
    Hello
    Quote Originally Posted by jshimm View Post
    I have recently got a 250 big red off a friend from work he hasn't ride it in some time I first off started by trying to clean the carb wasn't happening the jets were both broke so no way to even get them out so I took a carb off my 200 xr that I'm rebuilding it started right up one kick but when I drive it after about a mile or so it shuts down an won't start till it cools down still getting fuel down fall was had no tools to check plug for spark when it died were should I start
    An easy way to check if gas cap vent [as tri again suggested] is the problem is to simply crack it open a little then after the problem occurs and try it again or leave it open a little and try it on a flat road with less than half a tank so you don’t get splashed.
    If you try his recommendations and they don’t fix it then based upon those results and your current description of the problem it is an electrical one. Most likely the CDI.
    Take plug wrench and phillips screw driver with you when you ride to check plug and gas drain in carb if you want.
    Ohm the ign coil and stator coils per manual cold and hot. If they check out ok it is most likely the CDI.
    ORIGINAL MANUALS
    http://www.kb0nly.info/ATC/index.php
    Jan 2013
    minnesota
    5,911
    Hello
    How long does it have to sit before it starts again?
    CDI TEST - If it has to sit at least 40 minutes before it restarts remove the CDI immediately once the problem occurs and put it in the fridge for 15 minutes then reinstall it. If it runs again then do the test 1 more time. If results are the same then your CDI is bad.
    Jun 2013
    Okeechobee FL/USA
    59
    i agree with testing the gas cap first my 85 250es big red had a problem with the gas cap too, and then checking the cdi would be my next move
    King Trikester is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2013
    Canada, B.C, FSJ
    435
    The gas cap got me once, I had my 200m running perfect, went on a long ride and it pluged up, It would run fine and just die on me, I had to bomb start it over and over again until I finally took the gas cap off and it ran perfect, I was so mad at the machine I almost left it behind and walked home. such a simple thing made me feel realy dumb for not figuring it out sooner
