Results 1 to 15 of 25
Thread: that 60 SUCKS!!!
    Ithaca, NY
    2,596
    that 60 SUCKS!!!
    Ok, the little whore will only start with the airbox off and someones hand over the air intake. WTF??? plus, the homemade swingarm has NO provisions for chain adjusting. What it had was 2 chain rollers on 2 stupid plates and a spring. Well, I blew $40 at the bike shop to get a 420 chain and some new rollers. DAMNED if I could figure out how the hell it went together and what it did. So STUPIDLY i took another link out of the chain and now, its too focking short. I swear this thing is cursed. WHY WONT IT START?? first kick with a hand over the carb, it fires right up. I HATE THIS THING. I knew this would happen when I bought it.
    Haspin veteran '02, '03, '04, '05
    "Hey is your dash-cam on? Are we gonna be on C.O.P.S?"
    RECOVERING Trikeaholic
    Ashland City, TN
    2,576
    Hmm.....jets extremely lean or rich??? Carb too big? Something ain't right if you have to choke it that bad! Hmmm.....
    Trikes:
    1973 Honda ATC70-orange!
    (2)1985 ATC70
    1985 Big Red 250
    1985 250R
    Mar 2003
    NJ
    911
    i like it.
    86 KXT250B1 (4)
    87 KXT250B2
    85 ATC250R
    85 ATC350X
    84 ATC200S
    87 Banshee
    96 ZX7R
    G-MAN-1 is offline Just Too Addicted Arm chair racerJust too addicted
    ok
    i have to think about this 1................gimme some time?
    ok
    its either the air screw or the needle..........................................i bet 1 of these is the prob..................
    Detroit, MI
    837
    That's a lean mixture. Gonna have to do some carb tuning.
    1986 ATC 250R(for sale), 1963 AceCraft boat w/40HP Evinrude, 1981 Arctic Cat El Tigre' 440 L/C, 1992 GMC Safari Van.
    200xer is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sounds very lean.
    85 200x - Torn apart
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,239
    no matter how lean its jetted it should idle at least,,,, pull the float bowl drain plug and turn on the gas to see if you have good fuel flow,,,,if you don't have good flow its probably in the petcock,,, if you do have flow them its time to pull the carb down,,, the pilot jet would have to be completely plugged to keep enough restriction that it wouldn't even idle,,,,, ,,,, but if it won't even fire with the choke out ,which is a direct bypass of all the jets i would say that your tank or petcock is plugged,,,,
    Ithaca, NY
    2,596
    WRONG, all of you. It has a brand new factory petcock, and it will Idle once running. So now what???? Im really most interested in this chain adjuster thingy. Mabey I wont even use it..???
    Sep 2003
    Elizabethtown PA
    1,581
    it looks like they used a 84 or 85 200x swingarm that the adjustment is up front by the pivot bolt. the brake rotor.hubs and wheels look like old 200x parts. you could weld the back of a 86 or 87 swing arm to the one on the trike. or get it from any atv with the normal bearing carrier you turn to adjust the chain. that chain tensioner looks like one off the universal ones you can buy that will fit any bike.
    JASON LISKEY
    2 = 86 atc 350x's
    86 atc 250r
    speed20 is offline Check my feedback before buying from me Arm chair racerJust too addicted
    Jun 2002
    OH-IO
    816
    manifold have a crack in it????
    slippy4 is offline Just Too Addicted Arm chair racerJust too addicted
    May 2003
    556
    someone tell me what this thing actually is, or was?
    85 Tri-z
    38mm Flatslide
    Boysen Power Reeds
    DG Pipe and Silencer
    Bored 1.25mm over
    Wiesco Pistion and Rings
    K&N Clamp on Filter
    Compleating Restoration
    Jun 2002
    OH-IO
    816
    looks like a lil kxt60
    Ithaca, NY
    2,596
    "it" is a 1985 KX60 with a trike conversion kit on it. The kits used to be availabel out of dirt wheels mags and chit.
    May 2003
    556
    thats cool, like the way it looks anyway.
    85 Tri-z
    38mm Flatslide
    Boysen Power Reeds
    Bored 1.25mm over
    K&N Clamp on Filter
