Thread: Tri-z leaking oil from hose
    May 2008
    Tenn
    548
    My friend's Z is leaking some oil from the hose right above the stator on top of the motor at the bottom of the cylinder. I thought that hose was used for vent the casing below the cylinder? Any ideas on the cause of the leak?
    Thanks
    Just-Tri-It
    :Trikes Owned:
    1985 Tri-z's 3
    1986 Tri-z
    1984 YTM 200ERN 1
    zzmegad's Avatar
    zzmegad is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2008
    North of Chicago
    317
    i just looked at some cases I have, and yeah its a trans vent.. So yeah to much oil? or maybe it was upside down and a little left in the hose? What if there was a leak between the crank case and the trans? Could that force oil out the vent, or would that suck oil in?
    Aug 2004
    Ab Canada
    4,368
    If its over full it will spit it out at High RPM's...it is the trans vent.
    1985 Tri-Z-
    May 2011
    eden,ny
    3,481
    it will also puke if there is moisture in the cases
    May 2008
    Tenn
    548
    OK. Thanks. He said it doesn't leak while it's running or revving but after he shut it off. He came back and found a small puddle under the bike.
    Just-Tri-It
    :Trikes Owned:
    1985 Tri-z's 3
    1986 Tri-z
    1984 YTM 200ERN 1
