Results 1 to 8 of 8
Thread: 85 250es rear end help please
    kebby28's Avatar
    Nov 2012
    Antrim, NH
    435
    My left side rear hub is smoked. The splines on the axle are still good. What I was wondering, since I can't find one on ebay but I see a few of the right side, can I just put another right side on there? The part #'s are only off by one number. The only thing I know is different is the two screw holes on the brake side.
    Has anyone ever welded the striped out hub on and then slid the axle in...? would that work? Just trying to get ideas. It's kinda depressing not being able to find parts
    Oct 2012
    WI
    499
    I wouldnt recommend welding it but IF you do just do a few tacs and make sure you will be able to grind them off if you want to take it off. Nothing more annoying then people welding hubs on.
    Jan 2011
    Choctaw, OK
    2,755
    Don't weld it. Fix it right. The left hub is also shared with the SX left hub as is the right (85 only) so broaden your search to SX hubs.
    kebby28's Avatar
    Nov 2012
    Antrim, NH
    435
    I wont. I just got discouraged when I did a search here and found a lot of the 85's left hubs were stripping. I did broaden it to sx but still nothing on ebay but Howdy might have one.
    Van down by the river
    3,874
    Just holler in the classifieds. I should have one if howdy does not.
    R.I.P. John Swinehart
    Epic Mikfest 17
    86 200x
    85 250sx
    85 big red
    85 atc 70
    Jan 2013
    minnesota
    5,911
    Hello kebby28
    Here's some new originals if you don't find a used one.
    85 LT ES HUB $162.00 p/n 42620-HA0-000
    http://www.cmsnl.com/honda-atc250es-...0.html#results
    85 LT SX HUB $162.00 p/ 42620-HA0-000
    http://www.cmsnl.com/honda-atc250sx-...8.html#results
    85 LT ES/SX HUB $120.00 p/n 42620-HA0-000
    http://www.partzilla.com/parts/detai...0-HA0-000.html
    Sarnia, Ontario, Canada
    3,415
    Don't weld..please don't weld.
    I know it frustrating having trike down time..check with Cory (PS2Fixer), he's got a ton of parts ES/SX trikes...
    I bet you he's got what you want and can get it to you quickly..just PM him and be patient!!
    Then thank Honda for the forethought to make the hub of a slightly softer grade of steel than the axle..amazing how many have this happen and the axle is still good. This must be the reason for it!
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    Howdy's Avatar
    Celina, Ohio
    10,079
    Good axle splines = DO NOT WELD!!!! The axles are getting harder to find in good condition.
    Howdy
