Results 1 to 2 of 2
Thread: 200x oil pump
    Dec 2012
    greenville oh
    68
    200x oil pump
    How can I tell if the oil pump is working right, I traded a 250sx, for ALOT of 200x parts, ( I have 6). I just took apart two of the motors, One the rings was seized to the piston, the other, the can lobes wore down 16th inch and the rocker arms, Any one know why this happens, I have never run them, but before I put them back together, Help if You can, and Thanks
    Larry T Moore is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2013
    Indiana
    358
    usually you take the pump apart and check the wear between the teeth and between the gears and the sides with a feeler gauge...should be specs in the manuals
