Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 35
Thread: 1985 250r carb issues
    Auto_Demon's Avatar
    Auto_Demon is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Stonewall, Manitoba
    290
    Angry 1985 250r carb issues
    So just recently my 250r sounds like its not getting fuel, it was running perfect earlier today and now when u give it gas it bogs and dies, took the carb off and cleaned everything, cleaned the in tank filter, shortened the fuel line and put an inline fuel filter in and its still doing it, ive also noticed that there is an air bubble in the fuel line but its still getting fuel, what is going on? Can anyone help me?
    1985 Honda ATC 310R
    "Man your 4 wheeler must be fast, cuz you were haulin' ass, when I passed you on 3 wheels"
    Slidell, LA
    4,738
    Possible your jets are too big?
    Auto_Demon's Avatar
    Stonewall, Manitoba
    290
    Nope cuz it was running fine the day before and i did nothing to the carb, it was running good, we switched out tires and rims and then it started doing this
    1985 Honda ATC 310R
    Jan 2013
    minnesota
    5,911
    Hello Auto Demon
    Quote Originally Posted by Auto_Demon View Post
    When it “bogs” does it burble/stutter like it is rich or does it simply fail to build rpm like it is running out of gas?
    Pull plug out when it dies and see if it is wet.
    Pull hose off at carb and see if gas flows quickly or slowly. Try it on maain and reserve. Gas valve might be partially plugged. Fuel filters are occasionally restrictive but since you had this problem without the new filter it is likely ok.
    It’s strange but they always do, it is not a problem.
    GAS LEVEL TEST – If your gas level is low in the float bowl then your carb will be lean and may run out while riding mainly if there is a restriction in the line from tank to the bowl or at needle and seat.
    Install clear plastic tube on bowl drain, hold open end of tube level with top of carb and open bowl drain valve. The gas will flow into the tube. It should be from level to 3/16" below the bottom of the carb body where it meets the bowl. If it is incorrect then adjust float accordingly.
    Now tape that hose to carb, leave drain screw open and test ride. As soon as it dies look at gas level in hose. If it is low or empty then find fuel restriction.
    Mar 2012
    Ohio
    70
    What does your spark plug look like?That will tell you quite a bit.Post a picture of the plug.Could be running rich and just
    finally fouled it.
    Mine did the same thing.Ran perfectly then all the sudden had erratic idle,bogged down,sometimes would start sometimes
    wouldn't.
    Found my plug was fouled.Changed it and have been fine since.
    Heres a chart to help-
    http://kereta.info/wp-content/upload...lug-colour.jpg
    Auto_Demon's Avatar
    Stonewall, Manitoba
    290
    Didnt think it was fouled but now looking at that chart it looks like the plug is carbon fouled, ill post a pic anyways a little later. So ill replace it and see
    1985 Honda ATC 310R
    Auto_Demon's Avatar
    Stonewall, Manitoba
    290
    I believe its still running a bit rich but i dont know what else to lean it out with. The clip is on the highest notch on the needle, and i am running 32:1 ratio, and i have no aftermarket parts on it...yet, should i try removing the airbox lid?
    1985 Honda ATC 310R
    Mar 2012
    Ohio
    70
    What plug you running? BR9 OR BR8 ?
    Auto_Demon's Avatar
    Stonewall, Manitoba
    290
    Br9es plug
    Jan 2013
    minnesota
    5,911
    Hello
    If the plug is black and dry [powdery] it is rich, it it is black gooey and moist even the least bit it is burning oil and possibly rich.
    Does it smoke?
    Lots or a little?
    What color ids it, llite blue/gray or dark/black?
    Removing the air box will lean it out slightly on top end.
    You need to replace your plug or scrub every bit of black off it or it can miss fire.
    Auto_Demon's Avatar
    Stonewall, Manitoba
    290
    Forgot to take a picture of the plug before i cleaned it, doh. But the plug was black and dry, looked like it had carbon buildup on it
    1985 Honda ATC 310R
    82 250r's Avatar
    82 250r is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2007
    Utah
    278
    That's pretty lean unless your riding above 7000 ft.
    Try the clip on the 2nd or 3rd from the top.
    Auto_Demon's Avatar
    Stonewall, Manitoba
    290
    Quote Originally Posted by 82 250r View Post
    It was on the 3rd clip but it was too rich even at 32:1, i might have torun 50:1. I was running that on my 83 250r woth the clip on the highest notch and it ran perfect
    1985 Honda ATC 310R
    82 250r's Avatar
    Mar 2007
    Utah
    278
    32:1 works well for these machines...stick with that. Don't jet your trike with fuel/oil ratio.
    If it works well on the top clip, you are probably compensating for another problem imo.
    Things to check before jetting are:
    Compression
    Air Filter
    Reed condition
    Condition of electrical components
    Float height
    Pipe and silencer clogged
    Air leak
    Any of these can have you chasing your tail with jetting.
    I would start with the factory jetting after checking all of the above.
    You may want to look on ebay for an 86 34mm pj flat slide carb...those 85 pe round slide carbs are known to have issues.
    Hope this helps
    Marc
    Jackson MI
    1,688
    Does it have the original (carb Round slide)?? If it has a oval slide (idle adjustment on choke knob) from a 86-89 Atc/Trx then could you have the slide in the carb with the cut out facing forward. That will make it run rich as heck especially when idling, and up through half throttle.
    83 ATC 70.
    83 Tri zinger
    ATC450AF
    86 310-R Drag racer
