i have a 1981 atc 200. starts up one pull idles on its own. when you ride it around in it sounds like the timing chain is slapping or something is knocking. when it gets warmed up it gets worse. it does have a weisco piston and it blew a head gasket when i first got it. i dont know if the knocking would of had a reason for the blown head gasket. i pulled the flywheel out and tightened the timing chain.(i did it that way because i wasnt trusting the auto adjuster). it wasnt loose but i tightened it a little more to see if it was the problem. but it still knocks so what else could this be?
if its the 10.25:1 piston , just high test pump gas if ok .
