Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 33
Thread: 1983 honda 250r project! :)
    Jul 2013
    Underwood, MN
    65
    I just recently inherited my brothers 1983 HONDA ATC 250R. It hasn't ran since about '98 but ran good when it was parked. It also came with another '83 parts donor (minus the engine). I would like to make it a screamer but keep it within budget guidelines (the wife is making me save all of my receipts). Everything is stock on this thing (that I'm aware of) except for the GOLD head and wide rear axle. As I recall, my brother bought it from a dealer back in the day that acquired it from someone who use to race it. So I'm not sure what has been done to the engine. It has one bent front fork, broken rear plastic and some rust on the frame. I'd like to clean up the donor frame and repaint it before using that as my building ground. I was going to start by replacing the leaky front fork seals, rebuilding the carb, installing a UNI air filter and installing a set of Boyesen Pro Series reeds. Anyone have any comments/tips/mods for where I'd like to go with this thing? I'm unsure about any tuning with installing the reeds also (ie:jetting,etc). Any help would be greatly appreciated.
    Thanks!
ID:	172718   Click image for larger version.
    Sep 2011
    Ocean Beach, CA
    1,333
    love that custom painted tank
    there may be some porting done inside that motor. check the condition of the boost ports. if theyve been wallowed out, chances are that the exhaust port has also been raised.
    looks like you wont need much to have a complete runner! good score!
    May 2013
    Broome county, NY.
    120
    Sweet bike, one of my favorites! Don't keep those forks compressed like that though.
    Jul 2013
    Underwood, MN
    65
    OK. I will have to check when I get home in a few days. I'm not too knowledgeable on the 250 so what am I looking for as far as the boost ports? and the pictures I took were from when I just got home so the twins are unloaded now.
    Carthage NY 250r rules
    2,355
    If you can swing the funds Kustom Kraft will do a 290 bigbore.You send them a oem cylinder and head.The will resleeve it and match the head to a 76 mill piston.This is a good alternative to finding a 300 topend.
    250r rules
    Mar 2013
    Minnesota
    441
    sick goodluck!
    and you're from rosemount..not that far out!
    ~~ATC's Currently Owned~~
    1983 Honda 200x - Main ATC
    1985 Honda 200x - Parts Bike
    ~~ATC's Previously Owned~~
    1983 Honda 250R
    1984 Honda 200X
    1979 Honda 110
    1983 Honda 125M
    1984 Honda 200
    1983 Kawasaki klt 200a
    1986 Honda 200s
    ~~Other Toys Owned~~
    2012 Pro R 800
    1993 Polaris Indy 500
    2004 Yamaha 125
    1990 Thunder Kart - 250CC
    2001 Yamaha Blaster - 240kit, aftermarket exhaust, power reeds
    May 2013
    Delevan, New York
    104
    Sweet project... What are you doing with the extra frame? Either way keep us updated on your progress...
    1985 225DR
    1983 Honda 250R
    1972 Honda Us90
    Jul 2013
    Underwood, MN
    65
    I'm planning on transferring the engine over to the parts trike because its frame looks to be in better shape. I'm thinking about just doing a piston/ring job in the top end with a new set of reeds and possibly a bigger carb, if I can find one cheap.
    May 2013
    Delevan, New York
    104
    Sounds Awesome... I Just Picked Up A 83 But The Frame Has Been Cobbed Together.... Good LucK OnThe Build
    1985 225DR
    1983 Honda 250R
    1972 Honda Us90
    Jul 2013
    Underwood, MN
    65
    Anybody have some info/feedback on setting up the Boyesen Pro Series reeds? I'm thinking about using the stock 30mm carb with a Uni filter for now and possibly a slight overbore with the stock pipe. I've never really tuned an engine that wasn't stock...
    Jul 2013
    Underwood, MN
    65
    I'm looking at repainting my donor frame, since it's in better condition, and building that unit up. Anybody know what is a close color match for the factory Honda red?
    loshe191's Avatar
    Jun 2012
    north east Indiana
    214
    Nice looking project good luck with your build.
    Jul 2013
    Underwood, MN
    65
    UPDATE: Engine has a .040 over piston in it. Going to take the top end down to Gilomen Innovations this weekend to have them look it over. Got the donor trike stripped down to the bare frame. Going to wash and prep the frame for paint this weekend. 2 out of the 4 fork tubes are reusable. Picked up a K & N air filter on eBay for $29. Picked up a BR8EIX plug and new tube for the RH rear tire last weekend. Anybody know if the Boyesen Pro Series reeds are worth the $$$ and if there's any tuning that would need to be done if I run them?
    Connecticut
    1,605
    nice trike head to air foolers .com and become a member they won't steer you wrong on the questions you are asking
    Jul 2013
    Underwood, MN
    65
    Ok, so I checked out s.com but can't register. They ask 3 questions but I can't seem to answer them correctly...
    Anybody have some feedback?
