Results 1 to 8 of 8
Thread: 200S Piston Ring???
    mike84bigred's Avatar
    mike84bigred is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2006
    North Tonawanda, NY
    343
    200S Piston Ring???
    Putting new rings on my 84 200s. The new rings are made by ArmorTech. All is good but the middle oil ring. It looks smaller than the piston diameter and its a different design the OE one. It does not look like it would seal well. Anyone ever used these rings and had any problems, or is it a better design? Help me out please. I can post a pic if it would help.
    84'200s (Dad bought new in 84, long gone)
    84'YTM200 (sold 02)
    85'KLT160 (sold 05)
    84' Big Red (Cobra exhaust,good shape) sold in 08
    84' Big Red (Parts Bike, runs good though)sold in 08
    85' 250SX (New plastic, Clark Plastic Gas Tank, Web Cam Camshaft, Cobra Exhaust, Moose Jet Kit, etc..) sold in 2010 and highly regret!!!
    04 Polaris Sportsman (Swapped 400 motor with a 500, Polaris wheels w/Kendra Bearclaws, Moose Fender Flares, Brushguard, Warn Winch)
    84 200s (Needs work!)
    Oct 2006
    North Tonawanda, NY
    343
    Heres the 2 rings. Old one on the left, new one on the right.
    84'YTM200 (sold 02)
    85'KLT160 (sold 05)
    Oct 2006
    North Tonawanda, NY
    343
    Cmon guys, someone help me out. Wifes yelling at me to get this crap off the table! Lol
    84'YTM200 (sold 02)
    85'KLT160 (sold 05)
    southern ontario
    12
    I've never heard of armour tech but it sure does look different, hopefully someone on here can help you out.
    Nov 2012
    Waldoboro, maine
    791
    There was just a post by codyrosa, I believe he used that brand.
    http://www.3wheelerworld.com/showthr...ght=Armor+tech
    He had trouble with his but I think he didn't do a fresh bore. He might be able to help ya out.
    82 250r
    83 Big Red
    85 Auto-x
    If you've done business with me please leave me feedback
    http://www.3wheelerworld.com/showthr...ght=Bren_downe
    Mar 2007
    Texas
    5,045
    here are the differences. the 1 oil rings sit on each side of the ring pictured. that is the oiler ring not an oil ring. the 2 oil rings that are thin sit on each side of it and are called oil whipers actually. anyway, what the differences are is this the oem had thinner whipper rings while this one uses a thicher (wider as far as piston to edge size) than the oem. should be fine. just make sure the whiper rings are properly isntalled and seated correctly and your set. always isntall the oiler ring or center ring forst when doing oil rings. (3 in 1 set) I have sued both styles over the years and both work fine as long as theya re proeprly isntalled. actually the new ring is easier to work with than the older one in my opinion.
    good luck.
    mike
    ________________
    https://www.mikesatvfix.com
    Jan 2013
    minnesota
    5,911
    Hello
    You should measure your bore if you haven't. If it is out of round by .0015 and/or has a taper of .0015 or more the rings will not seal properly. The piston to cylinder clearance should also be measured.
    If all is good cyl should be honed with a cross hatch pattern to promote ring sealing.
    Jan 2013
    minnesota
    5,911
    Those rings are either Chinese or Taiwanese.
    The ring on the right is the most common however I personally would use the oem Honda style and Japanese made rings.
