My 84 200es is starting to burn some oil.i have a 185 motor that is pretty tight but I'm not sure if I could swap the top end or not.
yes, but you will loose 200cc and that also means loosing about 1.5-2hp.
you may be beter off just getting a bigger pisotn and have your cyclidner bores and honed to the new piston. plus you coudl get qa wiseco 10.25:1 and really get a decent runnign motor even with stocker parts. jsut need to re-jet carb is all.
________________
https://www.mikesatvfix.com
I second that, time for a bore and hone...
1984 Honda ATC200ES "Big Red"
1982 ATC200E "Hondie"
yeah... 192cc to 180cc...
'86 ATC350X - 'Go-Go Girl'
'85 ATC70 - All Original
'83 Suzuki ALT125 - Pieces
What the other guys said and why would you part out a good running tight motor?
