Results 1 to 15 of 19
Thread: 250R with 450R Swinger
    Bailey, CO
    67
    Before Pics
    Bike sat in someones backyard for 10+ years.
Name:	before (Medium).jpg
Name:	DSC02869 (Medium).jpg
ID:	173623Click image for larger version.
Name:	DSC02872 (Medium).JPG
    Bailey, CO
    67
    Upon disassembly the swingarm was cracked bad so I decided to go with the 450r pieces, some of which I had already.
Name:	DSC03204 (Medium).JPG
ID:	173626Click image for larger version.
Name:	IMG_0332 (Medium).JPG
    Poco Loco's Avatar
    May 2013
    Clap Saddle California
    389
    That looks sweet. Will the chain line up ok. Thats a tempting conversion. I like it. Did you have to shim the swinger? Or did it fit rite in?
    The link, 450?
    Shart Guard .......Use it !
    Pink Powerwheels Barbie trike
    1985 Crash and Burn champ
    Bailey, CO
    67
    The pregnant oven used to cook the new swingarm.
Name:	DSC03169 (Medium).JPG
ID:	173628Click image for larger version.
Name:	DSC03172 (Medium).JPG
    Bailey, CO
    67
    The chain lines up nearly perfect.
Name:	IMG_1910 (Medium).JPG
    Poco Loco's Avatar
    May 2013
    389
    How does the length of the swinger compare to the R ?
    Bailey, CO
    67
    I ended up just painting the rear pink Maier fenders for now. I have some new rear tires on the way. This thing screams!
Name:	IMG_1995 (Large).jpg
    Thanks to Louis, Fire and the others who helped with my swingarm questions.
    Bailey, CO
    67
    I think it's a half inch shorter than stock. There are some good threads on here that describe the swap. I'm using the stock 250r linkage with a Dura Blue lowering link on the rear. Up front I used some bushings from a YFZ450.
    Plattsburgh, NY
    2,311
    Looks good. I just did the exact same thing gold 450 swing arm and everything. I'll have "something else" for u very soon.
    If u go with the '06+ 450 swing arm I'm pretty sure it's exactly the same length.
    TPC TRIKES
    FSU Powersports
    RNS Powdercoating
    Plattsburgh, NY
    2,311
    Oh also what gold is that for powder coat?
    And u stated using the 250R linkage but it's the 450 linkage in the pic.
    TPC TRIKES
    FSU Powersports
    RNS Powdercoating
    Bailey, CO
    67
    Sorry, your right 450r linkage. My swingarm is an 06 which is same length, I believe the 07 is half an inch shorter. The PC is Columbia Coatings - Gold Metallic with a Super High Gloss Clear.
    Poco Loco's Avatar
    May 2013
    389
    I just got off of ebay. Thanks alot you a-holes. Now Im lookin to spend some $$$. Bottom line...how does it work? Is it worth the work and money?
    Plattsburgh, NY
    2,311
    Paule: '06 & '07 r the same. For the trx450r it was '04/'05 was first gen then '06 and up. There r small changes here and there from '06+ but swing arm isn't one of them.
    Poco Loco: I would have to say it's very worth it. Drops something like 7 pounds from the real of the trike. Could be more I forgot exact numbers. Then u have new rear components that r cheap and u can find everywhere including a honda shop.
    TPC TRIKES
    FSU Powersports
    RNS Powdercoating
    Bailey, CO
    67
    STL
    3,560
    very nice work! bike looks so clean now! also nice 'packing' in the silencer lmao
