Ok guys...will a fl350 intake boot really work on my 1982 250r with a stock diameter carb? I need an intake real bad and have access to an fl350 boot.
From what I have read within threads on this site, it works.
I too have read quite a bit about them having the same bolt pattern and the right angle, but I have yet to read where a stock diameter carb will clamp into it good enough. Everything I've read is focused on an oversized carb.
Perhaps my question should be,...will a stock carb clamp in good enough to work?
so my question is have you been looking on ebay for an intake boot? I would also put a shout on AIRFOOLERS.COM
Or
You can use the FL350 Intake and upgrade to a 38MM PWK Air striker.
If u think it runs great now u should really try a bigger carb.
TPC TRIKES
FSU Powersports
RNS Powdercoating
I tell you what man, I have two 85 R carburetors. One was given to me by a friend and if you pay the shipping I will give it to you! I will not guarantee anything cause I never used it but it does look great. It will not have the slide, needle or cap though but everything else is there.
1985 Honda 250r
