If you want some sheer grunt, resleeve the cylinder with a 500cc cylinder from LA Sleeve. The stroke will be shorter so it will be a 420cc. You can choose your compression ratio to match the fuel you would like to run. You will still have $$ left over for a K&N and a pipe......There is no replacement for displacement.
Shart Guard .......Use it !
Pink Powerwheels Barbie trike
1985 Crash and Burn champ
