Originally Posted by
Jordyraye
I have an 84 yamaha 200e shaft. I was wondering if I could put motocross forks on it? If it will fit in the triple clamps I just wonder if the axle bolt will still fit. Also my charging system doesn't seem to be working, I put a new battery and the electric starter worked for a week or two but now it doesn't and the neutral light seems to be dimmer until you rev it up a little. Also I'm running 25x13x9's in it right now do you think I could turn 26 inch tires with grip like silverbacks or something?
1st question..motocross forks? Did you have something specific in mind? Or is this just a general question whether they will all fit? If your thought is to put a motocross front end and wheel on there?? EWWW!
2nd question..charging system on this machine has been known to cause issues. There are a couple tests you can perform with a volt meter..all detailed out in the manual. Likely a bad stator.. Download it here: http://www.oscarmayer.net/atc/manuals/
Lastly the oversize tire question..my personal impression would be a big no on this machine. Though it seems to be a big thing on the Honda trikes, they seem to have a little tougher auto-clutch system. I myself wouldn't do this on the Yamaha..the extra strain of the heavier, larger diameter tires will probably bring on a clutch slipping problem and faster breakdown of your clutch components..
Think smaller and more agressive, especially since you will want the extra torque..I'm reading between the lines but assume that mudding it what you had in mind?
These are great..I have them on my SX. 22x12x9 will direct fit your rims..
http://www.bikebandit.com/kenda-k299-bear-claw-atv-tire
Current toys..
1986 Honda 350X..trail bomb!
Current non-trike toys:
1990 Honda TRX300FW
1995 Seadoo GTX
1998 Polaris Touring 500
1998 Club Car (electric)
