Results 1 to 9 of 9
Thread: Where did all my oil go,,,, 350X???
    Jun 2013
    Southern New Hampshire
    29
    I put a new motor in my X a about a month ago. I don't know the total history on the motor, but it had never been started prior to my install. It has a 410 kit, not sure of the compression.
    Anyhow, after running it for a few hours, I checked the oil. Nothing showing on the dipstick. The exhaust is clean, no blue smoke, no oil buildup in the pipe.
    It looks like there is a small leak between the case and the jug on the left side, but I really don't think that much oil could leak out without me noticing it.
    The bike is still running GREAT. I haven't added any oil because I'm planning on doing another oil change before I ride again.
    Does anyone know how much oil has been lost when it stops showing on the stick and at what point does it become seriously dangerous to the bike. I don't plan on testing it out, just want to know. I'm sure I didn't cross that threshold. I will be sure to measure the oil I drain from the motor so I see exactly how much I lost.
    Cheers!
    David
    Jun 2013
    29
    BTW.... I know there is a lot of debate over synthetic oil, but I was running Mobil 1. This is another reason I plan on changing the oil.
    Cornholio's Avatar
    Cornholio is offline At The Back Of The Pack Arm chair racerFirst time rider
    Aug 2012
    Staples Minnesota
    180
    How long after running it did you check the oil?
    Life is short, Party naked!
    1986 250r
    1984 200s
    1984 250r
    1970 us90
    1991 Yamaha Blaster
    1984 110
    1985 110
    1984 200x
    Jun 2013
    29
    At least 24 hours. I did check it once while it was hot right after changing it and it was low. I figured it was low because some of the oil was up in the top end and not drained down yet.
    Nov 2010
    Oshawa, On, Canada
    2,123
    Regardless of when it was checked it should never be that low. Part the machine on some newspaper after filling it up with oil, let it run, and watch where it drips from.... If its not smoking it is obviously leaking out of the motor somewhere. Most likely a cracked clutch cover from a chain jump.
    And ps, it should be on the top line right after the motor is running and there is still oil in the topend...
    1985 Honda 250r x2
    1986 Honda 250r
    1986 Honda 250sx
    1985 Honda 250sx x2
    1985 Honda 350x x2
    1986 Honda 350x
    1984 Honda 125m x4
    1984 Honda atc 70
    Yamaha tri zinger
    Yamaha 4 zinger
    Brap braaaap
    Mar 2013
    Minnesota
    441
    And DO NOT run it without oil.
    And i'd figure the problem out before you ride again, so if it leaks out completely and you're still riding.. you won't have an engine for long
    ~~ATC's Currently Owned~~
    1983 Honda 200x - Main ATC
    1985 Honda 200x - Parts Bike
    ~~ATC's Previously Owned~~
    1983 Honda 250R
    1984 Honda 200X
    1979 Honda 110
    1983 Honda 125M
    1984 Honda 200
    1983 Kawasaki klt 200a
    1986 Honda 200s
    ~~Other Toys Owned~~
    2012 Pro R 800
    1993 Polaris Indy 500
    2004 Yamaha 125
    1990 Thunder Kart - 250CC
    2001 Yamaha Blaster - 240kit, aftermarket exhaust, power reeds
    Jun 2009
    Leander TX
    2,217
    Only 3 possible answers here:
    - it was not truly full from the start
    - if it was, it's leaking out
    - if it's not leaking out, it burning and goin out the exhaust
    In my experience, Mobil 1 is hard to see in the exhaust.
    I think you can get at least 1/2 a quart in when it's off the dipstick.
    Jun 2013
    29
    All great info. I'm going to check it out tonight, hopefully everything is okay.
    Jun 2013
    29
    Okay, I drained the oil, was missing about 1/2-3/4 qt of oil. Changed the filter and topped it off. I put some newspaper under it and ran it for about 10 minutes. No signs of a serious leak and there are no signs of smoke or burning out the exhaust.
    I can see that there is two small leaks. The fist is at the head gasket on the left side, the other is between the jug and case on the left side. While it is leaking, it just doesn't seem like enough to loose that much oil so quickly. Anyhow, I'm planning on keeping an eye on it and tearing it down over the winter to check everything out and change the gaskets. I will probably re-torque the head bolts before riding again this weekend.
    Either these leaks are leaking more than I thought while riding it or it was never truly full from the start.
    I did take a close look at the case and there is no damage from skipping the chain. Thank Goodness!!!
    Cheers!
    David
