Results 1 to 15 of 17
Thread: Noisy axle Big Red '83
    Dec 2012
    The Netherlands
    35
    Hey guys,
    It's been a while that I've posted something, I've been very busy with a lot of things.
    In the mean time I've been to a offroad parc in Germany with the ATC's and ATV, was a lot of fun.
    Yesterday I took the Big Red out for a ride, but there was a sound by the rear axle, first I thought that
    the brakes were making the sound. After some futher inspection the nuts that are on the axle were very hot, is
    this normal?
    Hope someone can help me
    Regards,
    Yaïr
    Here is a pic.
    Honda ATC 200e Big Red 1983
    Honda ATC 200m 1985 Sold*
    Suzuki Ozark 250 2008
    http://instagram.com/yavv92
    http://www.youtube.com/yavv92
    Howdy's Avatar
    Celina, Ohio
    10,079
    Very possible the rear bearings are going bad. Check for any play in the axle / housing.
    Howdy
    Dec 2012
    The Netherlands
    35
    Ok thanks for your reply.
    Is it part 39 on this picture?
    ScreaminRed's Avatar
    ScreaminRed is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2013
    NC USA
    391
    Yea, part 39, but make sure you get seals too, part 20, looks like. The way you can tell is by rocking it back and forth and feel the "play" in the bearings. I have an '83 also.
    '83 Big Red
    '85 350X
    '86 350X
    '06 CBR1000
    '08 Road King
    '11 Electra glide Ultra Classic
    My feedback thread: http://www.3wheelerworld.com/showthr...or-ScreaminRed
    Dec 2012
    The Netherlands
    35
    How many do I need? Just one of each?
    It's a fun machine to drive, I didn't drove it for like a month and it started right up
    May 2013
    NC USA
    391
    Quote Originally Posted by Yair View Post
    You would need (2) #39, (2) #20. But, what i would do, since it is 30 years old is take it apart and see what might be wore out and replace everything that is. From the parts list there are orings and other dust seals that would probably need replacing also.
    '83 Big Red
    '85 350X
    '86 350X
    '06 CBR1000
    '08 Road King
    Dec 2012
    The Netherlands
    35
    I've lifted the big red up yesterday and checked for play (there wasn't any) and tightened the wheels up.
    When I got the brake drum off I discovered the problem. The drum isn't round anymore en is almost rusted through.
    Besides that the brakes where tightened up to the max, I've adjusted them and now the noise is gone.
    The thing is, I need a new drum but they can't supply a drum in The Netherlands.
    The price for a drum by cmsnl.com is €176,50!! (around $234)
    Is it wise to purchase a second hand on ebay or something?
    Is a brake drum interchangeable with other models?
    Or is there a US website with parts?
    Edit: I mean part 5 on the picture above.
    May 2013
    NC USA
    391
    I'm not totally sure about it being able to be swapped with other years, but i bet it is, at least for '82-'84. I would definitely keep an eye on ebay and also ask here in the forum. There are lots of people here who have parts lying around.
    '83 Big Red
    '85 350X
    '86 350X
    '06 CBR1000
    '08 Road King
    Jul 2013
    Maybee, MI
    63
    I think this comment kinda goes along with this thread...... What kind of oil/grease goes in the axle? Since I am in the process of sprucing up/overhaul/restore/improve/etc on my trike I would like to clean that out and refill it with some fresh stuff.
    May 2013
    NC USA
    391
    Quote Originally Posted by neverdone View Post
    Hey Bud, I'm not sure what trike you are talking about? '83 Red or your 250sx? On my red, which i haven't rebuilt the axle area yet, i would guess some good ole moly lube for the bearings and axle splines.
    '83 Big Red
    '85 350X
    '86 350X
    '06 CBR1000
    '08 Road King
    Jul 2013
    Maybee, MI
    63
    referring to my 250SX of course, but I would assume that the SX and Big Red use the same type of lube at the ring and pinion area...... or no?
    May 2013
    NC USA
    391
    I would assume gear lube is what you need. My'83 Red is just axle and bearings, no ring and pinion. I'm not sure if the later Reds use the same type of lube, but probably so. They shouldn't be much different, if at all.
    '83 Big Red
    '85 350X
    '86 350X
    '06 CBR1000
    '08 Road King
    Jul 2013
    Maybee, MI
    63
    Quote Originally Posted by ScreaminRed View Post
    It would have to have a ring and pinion doesn't it? How else does it engage the shaft??
    May 2013
    NC USA
    391
    Honestly, i'm not that familiar with your trike. So, i think best for you to ask someone who has one or has worked on them. I don't want to steer you in the wrong direction. Sorry i couldn't help more. Good luck!
    '83 Big Red
    '85 350X
    '86 350X
    '06 CBR1000
    '08 Road King
    Jul 2013
    Maybee, MI
    63
    I actually just found a manual online. Mine uses 80 weight gear oil.
    But also I was saying that your Big Red has to have a ring and pinion........ also known as the final drive........
