Well dham 1st question: Paint removal. If its a
job, chances are you can wipe it off with Acetone. If you want it off to bare steel you'll have to blast it.
2nd question: reflectors. Hell I dont know.
3rd question:Fender crack. Ive tried the redneck weld system before. Cut some old fender (same color) into a few strips and heat a chisel with a torch and touching the chisel to the crack and using the strip like a welding rod, blend the plastics together. Personally I dont like it. It will work. I
perfer the bailing wire stitch. This holds up much better. Dont forget to drill stop the end of the crack.
4th question: Bent forks, hell ya press em. It will take a wide press to do it on though. Creative pressing will make em usable again.
5th question: Hard water stains: Hell just use some Scotch Brite. Dont use CLR, its acid. Theres differnt grades of scotch brite just like with sandpaper.
Find the one that works best. Test on the underside of the motor. If you power wash too much the water gets where its not suppost to be
ie. stator, bearings ect.
Good luck, Im sure theres other ways to do all of this. These are just some ways Ive tried and used over the years.
Shart Guard .......Use it !
Pink Powerwheels Barbie trike
1985 Crash and Burn champ
