Does anybody know if there are any inline gas filters that have two inlets and two outlets. I have a number of Hondas that have two openings on the tank and two places on the carb. Room is tight and I would like to have only one filter.
85 Big Red
83 Big Red
84 125m
85 TRX 125
73 ATC 70
If anyone had them I would have thought it would be Beatrice Cycle, but I did not see any there:
http://search.store.yahoo.net/dratv/...tml%3Fquery%3D
I did find this one, but at $40 and probably too big for your engine sizes (see the bottom of this page):
http://www.aperaceparts.com/pingel.html
I found some also but they are about $40.00 or more. There is a company called Pingel, that I found them at. Guess I will just have to keep my tanks clean.
85 Big Red
83 Big Red
84 125m
85 TRX 125
73 ATC 70
I just use 2 lawnmower filters and cut the fuel lines different lengths so they are staggered. Although, if the rest of your tanks look anything like your Big Red, I don't think you have anything to worry about.
X2 on the lawnmower filters, they work great.
Currently Own-
84 250R My Baby/Project
83 Yamaha 225dx
79 Honda Twinstar - Big Ole Turd
Heres My Feedback Page
http://www.3wheelerworld.com/showthr...for-ColtonGG33
Yep thats what i do to, a couple inline fuel filters and stagger them in the lines, the a couple zip ties to keep them neat and i have never had a problem. I have the billet aluminum lifetime filters on my 200ES, they can be taken apart and cleaned then put back together. This makes a great setup because if you ever have a fuel issue you can just turn off the petcock and tear the filters apart without a lot of fuel spill, and it can be done anywhere anytime.
I have some of the plastic inline filters on my other trike, ATC90, but that one never goes far from home. The tanks are clean, but i like to use the filters as insurance, its a lot easier to clean/replace a filter than it is to tear down a carb because some dirt or bad fuel got in the tank.
1984 Honda ATC200ES "Big Red"
1982 ATC200E "Hondie"
Check out JetsRus.They have a lot more stuff besides jets.
I like the filters with a 90 degree inlet/outlet - especially on the 70s.
