Results 1 to 8 of 8
Thread: Fuel Filters
    Michigan
    1,144
    Fuel Filters
    Does anybody know if there are any inline gas filters that have two inlets and two outlets. I have a number of Hondas that have two openings on the tank and two places on the carb. Room is tight and I would like to have only one filter.
    85 Big Red
    83 Big Red
    84 125m
    85 TRX 125
    73 ATC 70
    JustEnough's Avatar
    JustEnough is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2009
    Elk Grove, CA
    334
    If anyone had them I would have thought it would be Beatrice Cycle, but I did not see any there:
    http://search.store.yahoo.net/dratv/...tml%3Fquery%3D
    I did find this one, but at $40 and probably too big for your engine sizes (see the bottom of this page):
    http://www.aperaceparts.com/pingel.html
    Michigan
    1,144
    I found some also but they are about $40.00 or more. There is a company called Pingel, that I found them at. Guess I will just have to keep my tanks clean.
    85 Big Red
    83 Big Red
    84 125m
    85 TRX 125
    73 ATC 70
    Soutwestern PA
    2,040
    I just use 2 lawnmower filters and cut the fuel lines different lengths so they are staggered. Although, if the rest of your tanks look anything like your Big Red, I don't think you have anything to worry about.
    Oct 2012
    Somerset County PA
    720
    X2 on the lawnmower filters, they work great.
    Quote Originally Posted by Howdy View Post
    Yea, looked like a monkey ******* a football. LMAO
    Howdy
    Currently Own-
    84 250R My Baby/Project
    83 Yamaha 225dx
    79 Honda Twinstar - Big Ole Turd
    Heres My Feedback Page
    http://www.3wheelerworld.com/showthr...for-ColtonGG33
    MN
    3,263
    Yep thats what i do to, a couple inline fuel filters and stagger them in the lines, the a couple zip ties to keep them neat and i have never had a problem. I have the billet aluminum lifetime filters on my 200ES, they can be taken apart and cleaned then put back together. This makes a great setup because if you ever have a fuel issue you can just turn off the petcock and tear the filters apart without a lot of fuel spill, and it can be done anywhere anytime.
    I have some of the plastic inline filters on my other trike, ATC90, but that one never goes far from home. The tanks are clean, but i like to use the filters as insurance, its a lot easier to clean/replace a filter than it is to tear down a carb because some dirt or bad fuel got in the tank.
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
    1,641
    Check out JetsRus.They have a lot more stuff besides jets.
    Jun 2009
    Leander TX
    2,217
    I like the filters with a 90 degree inlet/outlet - especially on the 70s.
