I don't no what to do with it I removed the nut from the tins ,crank is free and the bearings seem tight but the piston smacked the nut so there is little pieces in the bottom end . the cases are not damaged ,the tins are fine . I think im just going to send the bottom end off and have it split to check the crank and bearings and clean it out before putting a good cylinder on it![]()
