Results 1 to 15 of 22
Thread: siezed motor 250r
    poohbee1's Avatar
    poohbee1 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2010
    terre haute indiana
    404
    siezed motor 250r
    I was thinking about going to the badlands tomorrow took my wheeler out this afternoon and was pushing it really hard and seized it up tight. The filter was clean ,running it 32 to 1 927 maxima , jetted a little on the rich side ,running perfect ,no noises. The cylinder is stuck so bad I don't know how im going to get it apart to see how bad it is . any suggestions
    Southern MN
    1,875
    Take the head off and bang the piston down with a block of wood and a mallet. Pull the flywheel cover off and see if there is gas in there (tell tale sign of a really bad crank seal.)
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    poohbee1's Avatar
    Apr 2010
    terre haute indiana
    404
    thanks ill give that a try
    Sep 2011
    New Castle, PA
    1,134
    Good thing that you didnt try and keep starting it, or bump start it or anything. There was this guy on bansheehq that TRASHED his engine. i got some of the pics from it.
    His piston
    His crankcase. he had a picture of the cylinder, but he deleted it. It was pretty much all melted
    1983 212x "Mickey Dunlap" Powroll TT Trike -Blue frame, Supertrapp (looking for a Powroll DD), WEB Stage II cam, Powroll 6mm stroker, Wiseco 10.25:1 piston stock bore, ported, polished, +2 Swinger,White low-pros and 250R front fender, BAPP rear shock, Powroll Decals, NOS Carlisle R/A's
    Gone:
    '83 185s, '86 200x, '70's Full Suspension Hi-Performance ATC RD400,
    Arizona
    843
    Perhaps it was a cold seize. Did you let it warm up? Cold seizure was more common on the first water cooled 2 strokes. Because the piston warms up and expands more quickly than the cylinder sleeve, if you run it without letting the entire engine warm up it can seize. The tell-tale sign is scoring on four opposing sides of the piston.
    There was certainly some serous detonation gong on there....
    poohbee1's Avatar
    Apr 2010
    terre haute indiana
    404
    it was warmed up .I was going to take it apart but decided to just wait and leave it in until I get a new one. I don't want to have this thing in pieces all over my garage for a month. sad thing is I had a fresh ported cylinder ready to go on it but the bottom end has to be trashed. I was thinking about buying one of those 85 take out motors that come up on ebay all the time but I am kind of worried about a motor that's been sitting on a shelf for so long they usually sell for 1000$ not sure what im going to do yet.
    No, now they run 2K plus. They are just fine I have run 2 without even a clutch or oil seal failure.
    Last 85R motor I saw was 2500.00$ BIN.
    poohbee1's Avatar
    Apr 2010
    terre haute indiana
    404
    people ask 2000 $ but they usually sell for around 1000$ http://www.ebay.com/itm/Honda-250R-T...item3a828c7be3 asking and selling are 2 very deferent things and if I cant find one I will have one built
    You can rebuild one but it won't be new. Just as stated in the sellers ad.
    If I saw it at 1K, I would have bought it. Just like the discontinued parts, everything is on the rise......
    poohbee1's Avatar
    Apr 2010
    terre haute indiana
    404
Name:	blown up 001.JPG
ID:	175095 im going to dig into this afternoon hope it doesn't look like the one adove
    poohbee1's Avatar
    Apr 2010
    terre haute indiana
    404
Name:	blown up 007.JPG
ID:	175099Click image for larger version.
Name:	blown up 004.JPG
ID:	175100Click image for larger version.
Name:	blown up 005.JPG
ID:	175101 I cant believe this a nut has welded itself to the crank where did that come from I didn't put it there. the motor is not seized the nut is hitting the case
    Southern MN
    1,875
    WOW, do you think someone may have dropped it in the sparkplug hole or put it in your intake manifold to ruin your day?
    85 Yamaha Tri Z 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    81 ATC 200
    poohbee1's Avatar
    Apr 2010
    terre haute indiana
    404
    no ones ever been around it but me . the cylinder has never been taken off, the reeds have never been taken off by me anyway. the spark plug has been in it for 2 years the pipe has a good 6 hours of use on it . the only thing I have done to it in a long time is switch the gas tank from black to red
    Marty is offline Just Too Addicted Arm chair racerJust too addicted
    Nov 2007
    Mesa, Az
    644
    WOW i thought I have seen it all!!!!!
