Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 31
Thread: Changed to 5 Pin CDI....HELP
    Jul 2013
    michigan
    88
    I changed from the round 6 pin to the updated 5 pin. I bought the CDI from the link in the sticky and another member generously provided the plug. I got the 200ES started but only on full choke and full throttle. It will stay running off throttle and most of the choke but it is running VERY rough. Any ideas?
    Before the CDI change it ran great after tapping the CDI box with a screw driver.
    After the change it runs like crap.
    tripledog's Avatar
    Aug 2011
    Central New York
    2,182
    Are you sure you got a cdi without an electronic advance? If it has electronic advance, it will not be compatible with the mechanical advance of the 200es ignition.
    Jul 2013
    michigan
    88
    I guess not. I bought one off the link in the sticky thread. The link took me to a specific one and I bought it.
    This is the one that I bought. I am not sure if it is mechanical or electronic, it doesn't say. http://www.ebay.com/itm/321095193713...84.m1497.l2649
    tripledog's Avatar
    Aug 2011
    Central New York
    2,182
    Double check the wiring position if you followed the sketch I sent you. I have been wrong before, and I am sure to be wrong again. Where is kbOnly when you need him? That is the guy that can help you out.
    Jul 2013
    michigan
    88
    I confirmed wiring with Dr ATV image to be sure. I will double check when I get back home.
    Jul 2013
    michigan
    88
    Confirmed again. It is wired the same as to your diagram and dratv
    MN
    3,263
    Here i am! Sorry been busy as heck here...
    Ok, so it was running 100% before the swap but now it runs rough? Let me ask this, did you pull of the gas tank to get to the wiring and do the swap, or was the entire fuel system left alone? Because the fact that you have to put on the choke and full throttle sounds more like a fuel issue... But! lets troubleshoot this a bit.
    Wiring i see has been confirmed, so no issues there that we know of. Those CDI's that i linked to in that post, and the one you bought, is the exact one i have on my 200ES and it runs so smooth its scary. There is no electronic advance in that unit.
    Now the only suggestion i can make, other than could it be a fuel issue from tearing off the tank and possibly shaking some crud loose that got into the fuel system and the carb, is that its a bad CDI. There has been a couple guys on here that mentioned they had a CDI brand new, one of these cheap ones, that had issues. So its not impossible.
    Also, check your firing timing, i know i know, it ran good with the old CDI, but who knows if someone adjusted it in the past to make it run good with that CDI that was going to crap. Set the flywheel to the F mark and then check the alignment of the advancer and the pickup, move the pickup if you need to and get the lines on them lined up. Also inspect the advancer, there is no telling if its just a coincidence that something else happened.
    You can get the contacts back out of that plug, they can be released and removed and then plug the contacts back onto the pins of your original CDI, you could do that and see if it goes back to running perfect, if so then its just a bad new CDI, if not then its something else yet.
    We will figure this out!
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
    Jul 2013
    michigan
    88
    Any chance you could shoot me your number in pm and I call you tomorrow?
    tripledog's Avatar
    Aug 2011
    Central New York
    2,182
    Did I tell you kb was the man? YES I DID!
    Jul 2013
    michigan
    88
    I can get it to idle off choke. It still runs like crap when given any throttle.
    To clarify the only thing that changed from running good and now is installing the new harness and Cdi. I had the harness pulled down already so I could tap to start. Nothing on the rest of the bike has changed. My second Cdi box should be here later this week.
    Unless I try to wire outside the harness to the old one I can't go back. The terminals are bigger than the old ones and won't fit in the round plug. Anyone have that wiring diagram?
    Jun 2012
    Arizona
    71
    Bad grounds will do odd things.
    Like make them not want to rev up ect.
    Check your grounds!
    Did you put dielectric grease on all the connections?
    Jul 2013
    michigan
    88
    No on dialectic
    Jul 2013
    michigan
    88
    All Greek to me. Is this located near the pull start?
    Hoping the second Cdi I ordered comes tomorrow. Will advise if its any different
    Jul 2013
    michigan
    88
    I pulled that cap and set it to f. Not sure what to do now or if I should wait for that second box before making adjustments.
    MN
    3,263
    Ok first off, all the info you have been asking for is in the Service Manual, click on the link below in my signature to take you to my manual server, click on the 200ES folder and then download the service manual PDF file, all your questions and prayers will be answered.. LOL
    As for timing... Ok, the flywheel is set to F, now take the cover off up on the head, the one that says CDI on it. Inside there is the spark advancer and the pickup coil. With the flywheel set to F the advancer and the pickup coil should line up perfectly, they both have a line in their center, those lines should be lined up. If they are not you loosen the two phillips screws holding the pickup coil plate and rotate it until they line up. Thats how you check the ignition timing, really simple.
    I would check the timing, if thats all perfect then wait until your second CDI shows up. It could just be as simple as a flaky CDI. The fact that you say it will go off idle a bit but not rev up only means two things... One the advance is not working, or two the carb isn't giving enough fuel. But as you said it ran good before, when the CDI wanted to work, then its probably not fuel related.
    My CDI did the exact same thing, although i didnt use a screwdriver, i would take it off and smack it on the sidewalk a couple times then put it back in and it fired right up. The contact size was the same between my original and my replacement CDI. If yours are that much bigger i would make sure they are correct and making good contact with the CDI pins. If they are too big to fit into the round plug then just place the contacts directly onto the pins of the original CDI without the plug, thats how i did it with my CDI to make sure it was working before replacing the plug.
