Hi guys,
I stumbled across a YTM 200e last week. I've had cycles for years, but this was my first trike. I had no history of this one and traded a lawn mower for it, and since all I heard about three wheelers was pretty negative, I figured I'd see if I could just part this out. But then I cleaned the carb, checked the oil, and put in fresh gas, and the thing fired right up, idles perfectly-and sounds healthy. I actually enjoyed worked on it, and have grown to like its engineering. It's light enough to move around, but has more substance than a bike.
But, since I've got it it's been stuck in first gear. Engine off, can't shift it up or down. Engine running, can't shift it up or down. It'll idle at a stop beautifully, accelerate smoothly, and stop well. I can push down on the shifter and the bike stops-feels like a clutch? But it wouldn't shift. So I pulled the right side cover off last night and drained the oil-and found three 1/2 inch metal chunks loose at the oil screen. Uh oh. At this point I figure that some gear in the transmission is stripped. At the worst, some metal might have made it's way into the piston, etc.
I'm disappointed as I have started to really enjoy working on this bike. What's your advice at this point? Is this a known problem/solution here? I'm guessing there is no way around this other than to split the cases to get at the transmission, yes? Probably a gear is sheared? I'm not sure what would cause that, and I'm not sure I have the time for the repair. I'm guessing a gasket kit is pricey. Should I part it out? Advice?
