Thread: 1982 front tire and bolt pattern?
    May 2013
    Broome county, NY.
    120
    I am wondering if any of you guys use or have used the kenda max 22x11x8 on the front? My concern is based on the typical problem that the ATC 250sx has with some tires rubbing through the forks because they are just a bit too wide. Is that also a problem on the 1982 250r?
    Also I am wondering if the front bolt pattern is the same as the rear (4/130) on an 82 250r?
    Thanks!
    Sep 2011
    Ocean Beach, CA
    1,333
    shouldnt be a problem. ive run a Kenda Front max through the dunes on my 82 250R without issue
    front and rear bolt pattern for 82 250r is 4/130
    May 2013
    Broome county, NY.
    120
    Thanks, I appreciate it!
    Jun 2003
    South of Rochester, NY
    3,471
    Broome County? Did you get flooded out?
    Some Suzuki Quadsport rims are 4/130 ... also the rear splines are the same from what I understand (not 100%). I bought a set of Durablue Rear Hubs and they were advertized as 24 spline 4/130 Quadsport and Honda and they slid right onto a NASA rear axle and a OEM axle.
    Bruce "Hondaline" Hartman
    PS.... OEM rear rims are interchangeable with front if I recall.... Can use 4/110 on rear by using a 24 spline hubs from 200X or 83-84R. 300EX hubs will gain you a couple inches with the more popular 4/110.
    '86 ATC350X - 'Go-Go Girl'
    '85 ATC70 - All Original
    '83 Suzuki ALT125 - Pieces
    May 2013
    Broome county, NY.
    120
    Quote Originally Posted by 350x'inNY View Post
    no recent flooding that I'm aware of, but I live on the highest point in Broome county.
