Results 1 to 13 of 13
Thread: Tire Changer
    maxdallasfan's Avatar
    maxdallasfan is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    New Jersey
    381
    Tire Changer
    So I started to look at tire changers online, but of course, there are millions to choose from. So, instead I said, hey Max, why don't you ask the guys on the board what they use or recommend. So I've decided to ask.
    What tire changer do you use? I've tried the and chisel method to no avail. Even stomped on it, drove my truck on it. Heck, once I even cut the damn tire off, but the bead....oh the dreaded bead. Took me a week of grinding to get that puppy off.
    My ride:
    1985 Honda 250es
    Mar 2013
    Central PA
    2,362
    Been there and done that, after almost 30 years i took the original tires off my 200s after they dry rotted and started leaking, i ended up using the neighbors pneumatic grinder to get through the bead. He just has a bead breaker he made himself and some tire irons, $5 a tire. I would rather do that than do it myself.
    Mar 2008
    EastGreenbush, newyork
    3,494
    here was my solution! If you have the raw materials and a welder handy.
    http://www.3wheelerworld.com/showthr...de!-that-works!!
    I just broke down a set of original ties and rims on the sx, they were a bear, but I got em, and the mounting end works just fine, popped the new tires right on.
    Mexico
    9,018
    a No-Mar changer has been on my want list for a couple years, but I am not sure how one would work on an 8" rim.
    Mar 2013
    Baldwin, Wi
    603
    If you can weld aldochina's link is the way to go. But the Coats 220 is the easiest nicest tire changer/bead breaker I've used in all the different shops I've worked at.
    Poco Loco's Avatar
    May 2013
    Clap Saddle California
    389
    I use my gas powered wood splitter to break the bead. Then tire tools to finish it off
    Shart Guard .......Use it !
    Pink Powerwheels Barbie trike
    1985 Crash and Burn champ
    NC
    907
    Local Walmart is $5 per tire. So far so good.
    Connecticut
    1,605
    Quote Originally Posted by 200x350xtriz250 View Post
    That's funny I sent the wife with two 22x11x8 to have them get the crap tires off the rims at Walmart and the guy was like we don't have a key labeled on the cash register so I do not know what to charge he did them for free
    NEPA
    7,051
    If you go harbor freight,,be prepared to do some extra welding and lag it down good. And that will make a decent set up. Being on the farm having tires from wheelbarrows up to and including 30.5/32's,and 20.8/38's. A machine was never an option,so I still use a slam and hand tools. But I have been doing that for over 25 years so I might be pretty good at it..
    200xranger's Avatar
    200xranger is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jun 2007
    St. Louis
    207
    if you are just doing atv tires...i have the harbor freight bead breaker and it works very well. we have even done dune buggy tires with it.
    Three Wheels Are Better Than Four!!
    My Rides:
    85 250r atc
    85 tri z
    2012 honda rincon 680
    1,641
    I too have the Harbor Freight Bead Buster.Works well,rim holder needs to be closer.For $40 can't complain.
    New Jersey
    381
    Is that the portable one on Harbor Freight for $40?
    Yah I'm not a welder, so no dice on that. But thanks for all the info.
    My ride:
    1985 Honda 250es
    Apr 2006
    SE CA Dez in the sandbox
    892
    Harbor Freight + lag screws + 4x4s
    Finally had to reinforce the spade though after about 25 sets of tyres.
