Page 2 of 2 FirstFirst 1 2
Results 16 to 26 of 26
Thread: tri z Keihin 38 mm carb throttle cable triz 86
    Mexico
    9,020
    3Z with Fangs! is offline At The Back Of The Pack Arm chair racerFirst time rider
    May 2018
    Virginia
    184
    I meant to thank you for this publicly a few days ago!
    Mexico
    9,020
    No problem. What are you planning to use for a manifold with the larger carb?
    It sucks to get old
    Jan 2014
    Prescott az
    720
    I'm curious too.
    Sent from my XT1635-01 using Tapatalk
    [/SIGPIC]
    85 350x
    83 200x-sold
    ×2 85 200x-sold
    06 kx250f-sold
    86 tecate-sold
    86 tri z powervalved
    85 BIG red
    18 rmz250
    87 lt80
    19 ttr110
    May 2018
    Virginia
    184
    Heat the stock one, everyone says it'll work.
    Jan 2014
    Prescott az
    720
    Quote Originally Posted by 3Z with Fangs! View Post
    That's what I did just wondering if you went a different route.
    [/SIGPIC]
    85 350x
    83 200x-sold
    ×2 85 200x-sold
    06 kx250f-sold
    86 tecate-sold
    85 BIG red
    18 rmz250
    87 lt80
    19 ttr110
    May 2018
    Virginia
    184
    Quote Originally Posted by 6spdls1z28 View Post
    I haven't yet because I honestly don't have it all in hand. I ordered the carb, cable, choke pull and the nut and o ring for the bowl because I ordered a sled carb and they're a little different. I'm curious what I'll need to do for Jets but did order through CEL needle recommended in another thread.
    May 2008
    Tenn
    548
    Is this true for the Keihin 38 Quad Air Striker too or just the Standard Keihin 38 about the pump issue.?.
    I was thinking of using the Quad Airstriker.
    But if it floods, then I may go a different route.
    Thanks
    Just-Tri-It
    :Trikes Owned:
    1985 Tri-z's 3
    1986 Tri-z
    1984 YTM 200ERN 1
    Mexico
    9,020
    Quote Originally Posted by Just-Tri-It View Post
    Thanks
    I had flooding with a PJ and an AS, it’s the orifice size of the float valve that’s the issue, so unless you have a sled carb your going to have to deal with the issue of excessive pressure.
    It sucks to get old
    May 2018
    Virginia
    184
    Which is why I chose a sled carb!
    Jan 2014
    Prescott az
    720
    Just drill the t fitting out a little I haven't had a drip out of my 38mm airstriker in like 4 months even went to glamis never had an issue.
    [/SIGPIC]
    85 350x
    83 200x-sold
    ×2 85 200x-sold
    06 kx250f-sold
    86 tecate-sold
    85 BIG red
    18 rmz250
    87 lt80
    19 ttr110
