Sounds like you put the slide in wrong, make sure its oriented right, it can go in two ways, but only one way is right so that it slides all the way down. There is a diagonal notch on one side of the slide that goes towards the idle set screw, the other side has a long slot and rides on the pin in the carb bore. If you put it in wrong it wont go down and so you get a high rev and also little throttle response because its held partially open.
1984 Honda ATC200ES "Big Red"
1982 ATC200E "Hondie"
