What i have done to check for leaks on these intakes is to take my propane torch, just crack the valve open till i can smell a bit of propane and hear a faint hiss, then with the motor running you put that unlit propane torch tip around the intake and the intake to head flange and see if the engine changes speed. If it does then its sucking in the propane and burning it. I learned that years ago from an old mechanic that used it to check for vacuum leaks on cars, quick and easy way to find a bad fitting or cracked hose thats sucking air.
1984 Honda ATC200ES "Big Red"
1982 ATC200E "Hondie"
