85 125M - Timing Advance Springs?
Called Honda and you know how that turned out.
Searched the forum with no results.
Anyone know where to get some? Any spring kits you know of with some close to correct? I can make some just would like a starting point. Any from a newer bike that will fit.
One is broke and the other is just about broke.
Just bought a 82 110 and a 85 125M. the 110 runs great and the brakes even work. Just a leak on the fuel shutoff and the brake lever is broke. Minor stuff.
Paid $100 for the 125m because it was not running and all tires were flat but new. Well after I got all of the Sea Foam out of the gas tank, carb, cylinder and exhaust it runs good but idle goes up and down. After burning the sea foam out of exhaust it doesn't smoke at all. Checked the springs and they are shot.
//ArrowChat Integreation Code
