Thread: 350X Front Brake Pads
    Feb 2003
    New York
    619
    Put on new front brake pads. Now I hear rubbing sounds. Lifted front end up and spun the wheel. Seems like the new pads are thicker than oem ? I used Sumo kevlar pads. Is this a grind it till it fits fix ? Just wanna make sure the rotors don't get effed up. The rotor looks pretty straight to me when I spin the wheel. Anybody else experience this when you put on new brake pads ?
    Attached Thumbnails Attached Thumbnails SDC11699.JPG   SDC11696.JPG   SDC11697.JPG   SDC11698.JPG
    ♠ 58 ♠
    Ride 3
    Van down by the river
    3,874
    I had a similar problem with the rear of my 350x. I thought it was a bent rotor but it turned out to be the caliper was only compressing out of one side all the way. Did your caliper work correctly before you changed them? Look at your old pads, check to see if they were wearing evenly.
    R.I.P. John Swinehart
    Epic Mikfest 17
    86 200x
    85 250sx
    85 big red
    85 atc 70
    Poco Loco's Avatar
    May 2013
    Clap Saddle California
    389
    The caliper body slides side to side on 2 pins. These need to be cleaned and lubed from time to time. If the caliper cant center itself, it will ware the pads unevenly. Also the wheel wont spin freely. Dont grind anything.
    Shart Guard .......Use it !
    Pink Powerwheels Barbie trike
    1985 Crash and Burn champ
    Blossvale NY
    4,563
    Could be the caliper pistons having a little binding when being fully compressed in as well. With the pistons fully compressed and brand new pads, there is very little remaining clearance.
    So if any of the above issues aren't up to par, new pads will drag. Especially if the rotor is close to new spec for thickness...
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
