Results 1 to 8 of 8
Thread: yamaha tri moto 200 rear axle help
    Modale Iowa
    117
    ok guys I have a 1985 ytm 200 shaft driven with reverse. it wasn't doing a thing when put in gear so I tore the rear end apart and fount the bearings to be shot, and if I held the imput shaft I could turn the axle. I replaced the bearings and reassembled it and it seemed pretty tight and I couldn't hold the imput and spin the axle. I installed the rear end and start the unit on a jack and it drives forward and reverse then I put hubs and wheels on it and set it on the ground and it still wont move??? any help?
    Sarnia, Ontario, Canada
    3,415
    Did you by chance open the differential and check the gears?
    Is it making some kind of noise when you try to make it go??
    Sounds like your crown/pinion are blown apart..
    Shouldn't be hard to tell.
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    Modale Iowa
    117
    yes I had it apart, I put new bearings in it and no not really any noise the gears seem to be pretty tight but I guess not
    3,415
    Pull the driveshaft boot back and verify that the shaft is rotating..
    If its not you have a transmission problem.
    If it is you'll have to pull your differential back apart and see what you missed..splines in your differential where the axle slides in may be shot from the axle flopping around from the bad bearings!
    Current toys..
    1990 Honda TRX300FW
    1995 Seadoo GTX
    Modale Iowa
    117
    its a 200 there is no boot cause its a solid rear end. and I don't understand why it worked without tires and wheels on it
    Dec 2012
    Newfoundland
    140
    simple things first check the reverse lever, then the middle drive gears...once the relese button stops working on the reverse handle its easy for it to slip out
    1985 Yamaha 200E -ForSale!
    1986 Yamaha 250Dr (beartracker swap)Forsale!
    2009 Sportsman 850Xp
    2014 Renegade 800r
    2011 Dodge Ram
    3,415
    Quote Originally Posted by Yamahajake View Post
    Yeah right .. Thinking 225s
    Current toys..
    1990 Honda TRX300FW
    1995 Seadoo GTX
    3,415
    Newf is right..start simple.
    If it was skipping gears or sheared axle splines in the rear end you'd be hearing a bunch of noise from back there..
    Current toys..
    1990 Honda TRX300FW
    1995 Seadoo GTX
