does the yamaha 225 have a charging system?
ive kinda wondered the same thing
i have a 1984 225DX
i was kinda wondering if the rectifier was a charging type thing
i dont know
Ben
1982 Honda 200
1984 yamaha 225DX
1984 yamaha 225DX parts bike
1986 Honda cr250r (soon to be trike)
i was wondering because the battery always goes dead, maybe old weather? when i put a tester on the the two leads, no voltage was coming back, but i think that i may have a loose wire somewhere
i dont have an atv battery
i turned mine over with a car battery and turned over fine but didnt start and i dont know why
atleast i know my starter actually works
car battery is some voltage but has more amps than a atv battery tho
do u have a ground on the frame
well of course duh :oops:
im being weird this morning
Ben
this is my 225DX ive been talkin so much about
Ben
1982 Honda 200
1984 yamaha 225DX
Can anybody help us on this topic.
My old 1985 250R http://www.flickr.com/photos/24898661@N07/show/
Feedback http://www.3wheelerworldforums.com/s...feed+back+edog
Currently trikeless
Yeah, I'm digging way back here, but yes, it does have a charging system. It must. I have left my 84 Yamahauler in the "light" position for quite a few hours while lost in the bush one night, and when I went to use the electric start, I could just hear the click, and nothing. So I pull started it, drove it for a bit, then the next time I went to fire it up with electric start it worked no problem.
96 Warrior - 90 Moto4 - 86 Big Red - 85 Yamahauler - 84 Yamahauler - 82 Big Red - 79 Trail 90
yes it does. But it only charges at higher RPM's not at idle. Sounds like your bat. is spent.![]()
'WHEN IN DOUBT.........GAS IT!'
87 KXT250B2 Tecate
86 ATC250ES BIG RED
85 ATC350X
85 ATC70
'A FEW IN PARTS'
If you have a battery, you have a charging system. Output increases with RPMs, but they do charge at idle.
yes they do have a charging system, but it seems like most of them don't charge like they should anymore even with a new battery
They all start with a magneto coil and a magnetic flywheel which generates AC voltage. After that it must be rectified which means turned into DC voltage. DC voltage from Rectified AC voltage varies in amplitude, and is pulsed so it must be regulated. Voltage regulaters keep your output from going above around 14v. This is why you blow bulbs when the regulater has a problem.Originally Posted by CHAINSAW
As far as where they are located, the magneto, and the voltage regulater are usually separate components while the rectifier may be separate but now more often is combined or incorporated into another component.
