Does anyone know if it is common for the needle and needle jet in a carb to get worn so much that the engine will run rich??
Current Rides:
'87 Tecate 3
'84 Tecate 3
I GUESS ANYTHING IS POSSIBLE!!! i have never seen it in all my years,,, are you only rich in the mid range? cause it would have no affect on top end or bottom end?,,,, is it all original? is it a mixed match set?
i guess if the needle was sloppy in the slide it could wear on the jet enough to change things,,,
My needle was bent pretty bad.
Current Rides:
'87 Tecate 3
'84 Tecate 3
Is the needle supposed to fit snug in the jet?
Current Rides:
'87 Tecate 3
'84 Tecate 3
Yep....I'm pretty sure it should be snug. It is on 2 of my carbs.
Trikes:
1973 Honda ATC70-orange!
(2)1985 ATC70
1985 Big Red 250
1985 250R
mine fits kinda of loose
Current Rides:
'87 Tecate 3
'84 Tecate 3
i have replaced all my honda atc trikes and trail bikes with new needle jets and needles they were all running rich black smoke when replaced they run real good and clean plug i got my carb kits from this site no hassles http://www.mfgsupply.com/ATVCarbs.html/mv_session_id=6RIjekpU
1985 honda big red 250es
1983 honda big red 200 e
1985 honda xl 200 home made trike called fat tony
1985 honda xl 200 bike
1983 honda 200 es in off road kart
