Team Blue: 85 Tri-z 250: under the knife
Team Red: 87 Trx250r 01Cr80 15 CBR600RR
Team Yellow: 06 Ltr450 11 Hayabusa
The older DG and Phase 5 are the ones that had the J hooks. I'll take a scope out of my phase 5 and compare the two.
too many bikes to count. too little time on hand.
My dg has hooks like that but it also had dg stamped on the mount too.
The dg pipes looked very similar to phase 5. Im pretty sure yours is a phase 5
more pics of the pipe
i asked another member who has seen both the old school dg and p5 and said that the convergent portion of the exhaust after the mount bracket on the p5 has a noticeable curve down while the dg pipe has more of a straight bend. the p5 also has a larger expansion in the exhaust vs the dg. any inputs on that piece of info?added a pic for reference. i dont have a dg to do a side by side comparison of the expansion chamber, can someone who has one maybe take a measurement of the largest diameter of a true dg pipe so i can compare it and so others will have more info when trying to id their exhaust pipes.. i saw a pic of an old school dg pipe with j hooks and no dg stamp on the expansion chamber but had dg stamped on the rear mounting bracket mine has 222 stamped on it.
My Phase-5 has CCC stamped on the back of the top mounting bracket
What muffler are u running on your p5 c.j?
To be honest it looks like an older DG can. It's kinda trashed though so i was gunna try an whip somethin out to look like a Dr. Q 500 silencer for behind it
I was planning on chopping up an fmf from an lt 500 as well
