Can anyone give me some advice on replacing the oil pump drive sprocket (cam chain side) on an 82 ATC 70? I took the left side case cover off and could see that the drive sprocket is almost smooth, teeth are pretty much gone.
From the little info I could find you have to remove the right side case as well and use a screw driver to thread out the oil pump drive shaft, once that is done you should be able to remove the left side sprocket?Is there anything I am missing and are there any other special tools required besides the flywheel puller? Thanks.
(press) the new one on?
