Page 2 of 2 FirstFirst 1 2
Results 16 to 19 of 19
Thread: ATC 70 oil pump drive sprocket
    6,808
    Line a tooth on the sprocket with the key way , sometimes even from the factory their a little off so I wouldn't go by the old one .
    Quote Originally Posted by fastatc70 View Post
    Is there a key way for the crank gear or do you have to mark the old gear and press the new gear back in in the same location?
    fastatc70 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Aug 2012
    Northbrookfield, Ma
    166
    Good to know. The last time I did a gear I put everything together with out the stator plate and aligned the cam and crank with its marks and then removed the flywheel and tap the gear on with heat. It was a pain in the neck.
    Trikes:
    1985 ATC 70 mod to 184cc
    1984 ATC70 mod to 124cc
    1983 ATC 70 Xmas restoration
    Quads:
    1986 TRX 250R
    2002 TRX 400EX
    2- LT80 for the kids
    1986 LT 50
    Aug 2012
    Iowa
    148
    Your right, the 70 I am working on right now is slightly off the keyway. I ended up ordering a crank cam gear, clutch springs and new clutch disks too… I figured while I’m in there I will do just about everything I can.
    Aug 2012
    Iowa
    148
    Just wanted to post a few pics of a puller that I found that works really good for removing the crank timing sprocket. I was starting to get a little frustrated as I could not find a puller small enough or strong enough to get the sprocket off. (I bent the crap out of a smaller, cheap puller... You get what you pay for!) It’s a power steering pulley puller and costs around $25-$30.
    Attached Thumbnails Attached Thumbnails IMAG1257.jpg   IMAG1258.jpg   IMAG1261.jpg
