Results 1 to 15 of 19
Thread: ATC 70 oil pump drive sprocket
    Aug 2012
    Iowa
    148
    Can anyone give me some advice on replacing the oil pump drive sprocket (cam chain side) on an 82 ATC 70? I took the left side case cover off and could see that the drive sprocket is almost smooth, teeth are pretty much gone.
    From the little info I could find you have to remove the right side case as well and use a screw driver to thread out the oil pump drive shaft, once that is done you should be able to remove the left side sprocket? Is there anything I am missing and are there any other special tools required besides the flywheel puller? Thanks.
Name:	70 oil pump.jpg
    6,808
    You got the right idea now its hands on time.
    Aug 2012
    Iowa
    148
    Shortline10, Do you know what direction thread (left or right) the oil pump shaft is?
    6,808
    righty tighty lefty loosey lol . normal threads .
    Quote Originally Posted by Motorgidd View Post
    Aug 2012
    Iowa
    148
    Gotcha, thanks a lot!
    C.J is offline Just Too Addicted Arm chair racerJust too addicted
    Central, Louisiana
    639
    While you got it down I would go ahead and replace that timing chain as well. It looks pretty well used
    too many bikes to count. too little time on hand.
    Aug 2012
    Iowa
    148
    ^^^ Yeah I kind of thought the same thing… I got it all apart and the chain is definitely stretched... I’m going to replace the timing chain, cam chain roller and cam sprocket.
    Is it possible to change out the cam chain roller without removing the cylinder head? Can you slide the cam roller up and out through the cam sprocket cover?
    6,808
    If you can remove the center chain roller that bolts to the cylinder from the bottom it might be doable with out removing the head but I kinda don't thing theirs room . Never tried it .
    Aug 2012
    Iowa
    148
    Thanks for the reply Shortline. I tried it last night and I was able to get it out through the bottom... New parts are on order and should be here later in the week. Thanks for the help.
    fastatc70 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Aug 2012
    Northbrookfield, Ma
    166
    Take a good look at the crank timing gear. Also loctite the new gear onto the oil pump drive.
    Trikes:
    1985 ATC 70 mod to 184cc
    1984 ATC70 mod to 124cc
    1983 ATC 70 Xmas restoration
    Quads:
    1986 TRX 250R
    2002 TRX 400EX
    2- LT80 for the kids
    1986 LT 50
    Aug 2012
    Iowa
    148
    Quote Originally Posted by fastatc70 View Post
    Thanks for the heads up Fastatc70. Crank timing gear looks ok...
    I heard you can replace the crank timing gear without pulling the crank, using a puller of some sort. Anybody had luck with that? Just wondering incase I ever do have to replace one.
    6,808
    Can use a baby dermal cut off wheel to remove the old timing crank sprocket or I use a bearing puller if theirs room for it .
    Aug 2012
    Iowa
    148
    Gotcha, thanks. In your experience is it very hard to get the new one pressed on? I would assume you use a piece of pipe that fits over the crank and gently (press) the new one on?
    6,808
    I use a deep well socket to install a new sprocket , a little WD on the shaft and the new sprocket goes on with a few light taps . Just line a tooth perfectly up with the crank shaft keyway .
    Aug 2012
    Northbrookfield, Ma
    166
    Is there a key way for the crank gear or do you have to mark the old gear and press the new gear back in in the same location?
    Trikes:
    Quads:
    1986 TRX 250R
    2002 TRX 400EX
    1986 LT 50
