Results 1 to 10 of 10
Thread: EBC clutch removal tool for tri-z (anybody tried it?)
    May 2013
    Quebec, Canada
    134
    Just got my clutch tool and it doesn't seem to fit, many sellers on ebay have the same one listed for the tri-z model ct008. It does fit on the clutch boss but not in the basket. Only four notches align with the basket, I'm thinking of cutting the other notches, as long as I can hold the boss I guess it'll be OK. Anybody seen this before or do I just have the wrong tool?
    Thanks
    Attached Thumbnails Attached Thumbnails clutch tool 001.jpg   clutch tool 002.jpg   clutch tool 003.jpg
    9,016
    That is weird. Call EBC and ask. If you are in rush to use it you could cut the tabs like you said, but good luck getting it exchanged after that.
    United States of America
    EBC Brakes USA inc, 12621 Encinitas Avenue,
    Sylmar, CA 91342
    (001) 818 362 5534
    sales@ebcbrakesusa.com
    (001) 818 362 2196
    May 2013
    Quebec, Canada
    134
    The seller I got it from is contacting EBC about this but yes I'm a little anxious to ride my Z, as soon as I get my parts I think those tabs are going to get cut off.
    Apr 2008
    NW, IND.
    842
    Or find someone to weld a handle on an old steel clutch plate?
    80' Honda CR80R
    78' Honda XR75
    77' Honda CT-70
    74' Honda CT-70
    75' Yamaha GT80 Enduro
    76' Kawasaki KZ900
    73' Kawasaki H1-500
    76' Kawasaki H1-500
    Columbia
    5,131
    Jul 2012
    Seattle, Washington
    1,543
    Ive always been able to pull my clutch off without any clutch tool. Id just carefully wedge the handle from my channel locks between my sorocket and case, this locks up everything and allows you to remove the clutch. I used a pair with the rubber handle do it does not scratch up my case.
    Or the circle end of a 13/16 wrench on the sprocket will work the same way.
    Anyone else do this?
    6,798
    Use a Air impact to remove the nut and you don't need those fancy tools and guess what ... its universal for all models .
    Apr 2012
    USA
    4,133
    +1 That is what I do too lol.
    May 2013
    Quebec, Canada
    134
    I used an air impact to remove the clutch, I got this tool so I could tighten the nut to the right torque when reinstalling.
    6,798
    Well then the title of your thread is incorrect .
    Quote Originally Posted by dave ytz250s View Post
