Thread: ATC200ES Gurus - Refresh my memory please
    Tionesta, PA
    5,744
    OK - so I am about to help a friend of mine do a 200ES rear end swap. His old one is super horrible and after rebuilding one years ago I said never again. I found a good rear end from a friend of mine on here (Thanks Xowner!!!) If memory serves me, I had to take the motor out to do this before. I did this swap many years ago and can not remember what all is entailed. Something tells me the drive shaft only can come out thru the front (motor side) of the drive shaft tube.
    Help me - so I don't get the proverbial "Reverse - Shaft"
    Oswego NY
    1,935
    I sent you a text..
    MIK6/ Mike
    New England Ride 4/13
    MN
    3,263
    All you do is support the frame on some jackstands, take the band clamps off the driveshaft boot and pull that off the motor and then take apart the rear and and pull it off. No reason to pull the motor. Reinstall the reverse of removal just lining up the driveshaft as you slide in the new rear end.
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
    Tionesta, PA
    5,744
    Thanks guys!!! I appreciate it!
