My 85 110 started making a rattling noise. So I just assumed it was the timing chain loose. I took apart the CDI assembly, down to the timing chain, then I just put it all back together after examining the timing chain. Then I started it up, and rode it like 3 feet, and it made a really loud screeching noise (sounded like a car with a bad belt) so I shut it off immediately. Then I started it back up and the sound was gone. Then I rode it a little, and it made the screeching noise a couple times but not as loudly. Then I rode it around a bit, and it was just making the rattling noise coming from the timing chain. Then when I slowed down to park it, then it died, then it made this weird knocking noise a few times. It sounded like it could have come from the rear end or the transmission. Like a Bering just got destroyed or somthething. Then I started it back up and it died. This time it didnt make any weird noises besides the timing chain. It has a horrible transmission, that is always slipping into neutral and shifts rough, with neutral between all gears. Lately it has sounded like there's a broken piece of metal inside the transmission just moving around in there. The bad transmission is always grinding also. So, my question is, what do you think that screeching noise was? And what about the loud knocking noise? And it won't start now, but I think it may be a carb issue. This is just my little beater 110. I ride it everyday and just beat it up. I'm trying to get what I can out of it before the transmission doesn't work at all. I rode it all day for 2 days straight before I had these problems. I had a good time on it while I could. I'm going to work on the carb and see if I can get it started again.
If you read the whole thing, thanks! Let me know what you think the screeching noise was, and the knocking noise was. Plus the fact that it won't start. (I think it's a carb issue because I cleaned te carb right before I rode it when it made these sounds.)
I would run a compression check and compare against OEM specs. I would also make sure valves are gapped appropriately.
