Page 2 of 2 FirstFirst 1 2
Results 16 to 30 of 30
Thread: Wired in a cheap-o Chinese ignition switch '84 200es
    ericmreimer's Avatar
    ericmreimer is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2013
    Splendora, TX
    296
    Doug you are 100% correct these damn kids nowadays, I tell ye, such whippersnappers! Lol in other news I got my $4 brake lever in the mail today. Whoo hoooo!
    1984 Honda ATC200ES saved
    Project in progress 1984 ATC200ES with Trx200 rear suspension/200m front suspension
    Apr 2012
    USA
    4,133
    I'm one of them damn kids :P, except I fix the throw away junk like Ipods etc . The main thing we need good is the drive system and the engine, switches are simple, unless the honda ones are silver contacts, or gold plated, I don't see why they are so expensive. I think your buying the name more than anything on that. Now if I'm going to replace a transmission gear, I'm not grabbing one out of a Chinese engine! Way too much time to tear down an engine that far for cheap parts, but a switch that takes maybe 10-15 mins to install I'll skimp on.
    @ericmreimer
    That "OEM" brake lever looks like pretty high quality =D.
    Jul 2013
    Splendora, TX
    296
    I'm prolly one too I'm mean those crusty 37 year old tools got me beat.
    Dec 2012
    812
    I hear what you're saying Doug, yet I also believe that sometimes you can get away with not using an OEM part. I've gone aftermarket on things such as brake cables, wheel bearings, air filters, carb kits, etc., in the past and haven't been dissapointed yet. The argument could be made either way I suppose.
    1985 Honda ATC 250ES
    1985 Honda ATC 250SX
    1984 Honda ATC 200M
    1983 Honda ATC 200
    1984 Honda ATC 110
    Pacific NW
    4,255
    My switch was on the front porch today.
    Bag was ripped and not sure if it fits in the 250 dashboard yet
    but for * bucks, I'll just put it in the trike and not hook it up.
    Anyone who sits on it will ask, "where's the key", to which I can say, "i forget'
    and maybe they'll walk away and leave mmy machines alone.
    MN
    3,263
    I put one of those cheap switches on a 125M about three years ago, still works perfectly fine to this day.
    Don't let the OEM branding fool you. You honestly think Honda made the switches anyway? Chances are one of the companies making these cheapos was a producer for them back in the day. A lot of the Honda parts were rebranded from another manufacturer that made them for them. Sure they had the quality control over them but they didn't make them.
    I have had a couple of the Honda switches apart, they appear to be the standard plated contacts, maybe gold but they tarnish easily once you wipe off the dielectric grease. I had one of these cheapos apart too, look almost identical inside. Now i wish i would have taken pictures, put them side by side and play pick the OEM. I bet a lot of people would have picked wrong.
    I have no problem with aftermarket parts, especially when most of the parts are no longer available OEM and you gotta do what you gotta do. I have had good luck with most of the parts guys call chinese crap, so i guess my experience is far different.
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
    Apr 2012
    USA
    4,133
    Quote Originally Posted by kb0nly View Post
    Thanks for the info , I was wondering why it sounded like the honda switches lol.
    Anyway, I made up one, and test fitted it in a junk dash from a 200ES, and it can spin in the dash, but I looked into it further and it looks like the hole is oversized a bit by the old bad switch. Just to point out though, the stopper is a bit smaller than oem. I think a good dash it will be fine. Been thinking about finding a dash that would look ok, and throw it on my 350x (actually hooked up though lol). Heck I could wire them up and sell them if anyone had interest, not sure which dash would be good though, maybe something off a newer Honda quad.
    Uploaded is a photo how I wired mine . Model on the bag is EL-K0006 and of course "Made in China". Just a note, the tabs that hold the switch in are MUCH TIGHTER than oem's 6 lightly sprung ones. It is a real fight to install or remove. Also the clocking of the switch matches up with the dash markings which is a nice touch.
    MN
    3,263
    A little epoxy would keep it from spinning.. LOL
    You could even buy the Honda key rubber and put it on the cheapo switches keys and none would be the wiser...
    Apr 2012
    USA
    4,133
    I'd rather have a correct fitting part, since I'm half hoping to sell these prepped for install . Just an cheaper alt to oem Honda brand.
    MN
    3,263
    Problem is the Honda switch gets loose and starts to move and then it wears out the hole. Been there done that. I had one that would spin regardless of being an OEM or a cheap switch. The hole was just wallowed out. I put a little two part epoxy on the points of the new switch that push against the sides of the hole and then popped it in. After the epoxy was dry no problems. Other than replacing the dash entirely there wasnt much else i could do.
    Lancaster, PA
    1,738
    I use these also.I have them on the Mini Tiger, Mini Red and a Honda Express No ped. Fits perfect on the express, on the others that are using the standard Honda Dash, I just file a new notch where one of the tabs sits so it acts as a lock tab so it does not spin. Depending on the application you need to change the ends, and double check the wiring because I had them with the same plug but the wires were in different locations.
    1985 Tiger 250LC
    1985 Tiger 200LC
    1985 ATC 350X
    1985 ATC 200x
    1973 ATC 70 (resto project)
    and many more!!!
    Blue Line Graphics
    MN
    3,263
    Never thought of filing a notch, good tip! Last one i worked on the hole was so worn out from a spinning switch i just epoxied it but filing a notch would have helped prevent it from moving.
    Pacific NW
    4,255
    Quote Originally Posted by Big G View Post
    Thanks for sharing Eric. The key on my '85 250ES is starting to go on the fritz. Anyone know if these would fit that model as well?
    OEM key switches do come apart and can be cleaned.
    Do you have to wiggle to get your neutrallight?
    Try the search key for a Great post on how to.
    clmeue37's Avatar
    clmeue37 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2012
    Millington, Michigan USA
    205
    Good thread! Picked up an 84 Big Red a few weeks ago and the ignition switch was missing altogether. The previous owner had drilled a hole in the dash and wired up a toggle switch. I ordered one of these switches and while I waited for it to arrive I filled the hole with jb weld where the toggle switch had been and cleaned and painted the dash. Wired up the new switch according to the positions referenced here and it works perfect. Now I just have to get the rest of the wiring harness cleaned up and sorted out.
    Thanks for putting this information on here!
    1980 Honda atc110, 1981 Honda atc110, 1983 Honda atc200e Big Red, 1984 Honda atc200es Big Red, 1984 Honda trx200, 1985 Honda atc200s
    Trikefest '15 '16
    Before destruction a man's heart is haughty, but humility comes before honor.
    -Proverbs 18:12
  15. #30
    Jan 2014
    La
    1,062
    The dan gum honda key switch rubber cost the same as this hole key and switch set. I'm sorry this is 6 dollars for this switch and 50 for the honda and the way I see it is a switch is a switch.
