Results 1 to 13 of 13
Thread: New member with Honda 70 issues
    Sep 2013
    Bend, OR
    7
    Question New member with Honda 70 issues
    Hey everyone,
    I have been reading some of your blogs for a while now, but I have ran into a problem with my 1981 Honda ATC 70. I bought this thing for $200 and it was in pieces, literally in a bucket. I downloaded the manual and began ordering parts and putting it together. I got the timing down, gapped the points (great spark), have about 110 psi for compression and when I turn it over with a drill gas will eventually run out of the overflow. I even have tried starting fluid to get it to pop, but it won't. Honestly doesn't even seem like it's trying to run, am I missing something? Any help will be greatly appreciated, thanks.
    Sep 2013
    Have you checked your carb float and float needle ? You could try taping it a few times with something if your lucky it will come unstuck. If that doesn't work you'll have to open it up make sure the float is level with bottom half of the carb and you can clean off the needle. Hope this helps
    fastatc70 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Aug 2012
    Northbrookfield, Ma
    166
    Even if the carb was bad it would still start with starting fluid and a drill. I don't know. You said the timing was good? New spark plug?
    Trikes:
    1985 ATC 70 mod to 184cc
    1984 ATC70 mod to 124cc
    1983 ATC 70 Xmas restoration
    Quads:
    1986 TRX 250R
    2002 TRX 400EX
    2- LT80 for the kids
    1986 LT 50
    6,798
    New points and condenser ? Make sure you replaced them even if they look good and show spark .
    Van down by the river
    3,874
    I have to agree with shortline, even if they look good you should replace them for as cheap as they sell for. Need a pullstart? I have one if interested i would sell. Welcome to the site.
    R.I.P. John Swinehart
    Epic Mikfest 17
    86 200x
    85 250sx
    85 big red
    85 atc 70
    Sep 2011
    New Castle, PA
    1,134
    X3 on the points. Man o man i would love to be where you are. I would take a drive to powroll once a day
    1983 212x "Mickey Dunlap" Powroll TT Trike -Blue frame, Supertrapp (looking for a Powroll DD), WEB Stage II cam, Powroll 6mm stroker, Wiseco 10.25:1 piston stock bore, ported, polished, +2 Swinger,White low-pros and 250R front fender, BAPP rear shock, Powroll Decals, NOS Carlisle R/A's
    Gone:
    '83 185s, '86 200x, '70's Full Suspension Hi-Performance ATC RD400,
    Sep 2013
    Bend, OR
    7
    I appreciate all the replies, I did replace the points and condenser. I also replaced the coil, but through testing I ended up frying it and am back to the original, but still has great spark. The timing is set, I hit top dead center on the compression stroke, the timing notch and the O line up when the flywheel is on T. Thanks for the offer on the pull start, but I do have one. I just got tired of pulling the cover on and off to adjust the points. Could the tappets not be set right? I set them at .05mm. I appreciate any help, about to take it to a mechanic but really wanted to accomplish it myself.
    Aug 2012
    Northbrookfield, Ma
    166
    Spark is good. If it is in running order mechanically it will start on starting fluid. Is there a large air leak? Is the intake valve not opening is the exhaust plugged. Mouse nest. Is there an exhaust on it? You said the compression was 110 psi? Sorry if I am repeating my self just thinking out loud.
    Trikes:
    Quads:
    1986 TRX 250R
    2002 TRX 400EX
    1986 LT 50
    Aug 2012
    Northbrookfield, Ma
    166
    How much for the pull start?
    Trikes:
    Quads:
    1986 TRX 250R
    2002 TRX 400EX
    1986 LT 50
    Sep 2013
    Quote Originally Posted by fastatc70 View Post
    Your right I somehow didn't read that part I was addressing the overflow. It was pretty late when I was typing.
    Sep 2013
    Bend, OR
    7
    Had a breakthrough guys, SHE'S ALIVE!!!! I now have a different problem. It starts pretty easily but the idle screw and air/fuel screw doesn't seem to do much. It runs better and is more responsive when the choke or butterfly is closed. I didn't put air cleaner on it, should I put it on to adjust carb?Also there is a good size exhaust leak, but I have a gasket on the way, could that effect it at all? I also put my hand where the air filter goes on and seems to have a lot of fuel on it? Is this normal?thanks everyone for the responses.
    6,798
    If its the stock carb it needs the factory air box to run correctly that's including the filter , those motors need lots of intake back pressure to run properly .
    Quote Originally Posted by BillyBon3s View Post
    Sep 2013
    Bend, OR
    7
    Thanks shortline, put the filter on and adjusted the carb. She is running good, now to work on the cosmetics. Kids are going to have a blast this weekend. Thanks again everyone for you input.
