Help testing a ignition coil 125m atc
Hey guys, I am kinda new at this so if I stated anything wrong let me know.
problem is checked the ignition coil didn't budge on my meter few mins later checked to make sure, because it had ohms the day before well now it shows like 50 ohms on RX1K and I believe on secondary it shows that its sitting at like 10, which is then multiplied by 1,000 gives between 10,000 and 50,000 ohms (If I am correct.) and when done with Rx10 I get absolutely nothing at all. ( These are the only two setting I have on this meter until my new one comes in.)
Am I doing this correctly ? and is my ignition coil bad ?
Thanks
//ArrowChat Integreation Code
