Page 15 of 38 FirstFirst ... 5 13 14 15 16 17 25 ... LastLast
Results 211 to 225 of 560
Thread: Putting things in places they ought not to be (250R Hybrid Motor build)
  1. #211
    Mexico
    9,018
    Quote Originally Posted by Thorpe View Post
    Nothing like having 60 feet of tig weld into a pipe! Reminds me of tigging in a Model A roof panel, or some of the custom Boss Hoss tanks we built back at the rod shop...
    Ever look inside a rocket thruster? I swear there is at least a mile of flawless TIG weld in each thruster. It's nuts! Whoever welds those could likely weld up a complete 2 stroke pipe on his coffee break!
  2. #212
    Buffalo, NY
    1,995
    Robots dont take coffee breaks, camex
  3. #213
    Mexico
    9,018
    Haha I'm pretty sure no robots worked on the ones I saw in the Smithsonian.
  4. #214
    Billy Golightly's Avatar
    Live Oak, FL
    15,069
    Tracking finally updated - Just left NJ yesterday, so they made it across the pond atleast!
  5. #215
    Live Oak, FL
    15,069
    It made it!!!!!!
    The customs slip says "Sheet metal puzzle - 90 pcs" Thanks Hagen!
  6. #216
    Maryland
    3,077
    Thats a nice looking pipe right there!
  7. #217
    Oct 2007
    Minneapolis mn
    4,067
    Quote Originally Posted by Louis Mielke View Post
    Some assembly required....
  8. #218
    Mar 2007
    Texas
    5,045
    hahahya billy, you got yourself into a pretty big pickle!
    ________________
    https://www.mikesatvfix.com
  9. #219
    Live Oak, FL
    15,069
    Oh I'll get it - don't you guys worry. Just going to take a bit of time
  10. #220
    Mexico
    9,018
    Is there a picture on the box you can copy?
  11. #221
    Live Oak, FL
    15,069
ID:	199834Click image for larger version.
ID:	199833Click image for larger version.
    One major hurdle out of the way - all the sections have been rolled and welded on edge. I still need to do some finish forming (the last edges will always be flat on stuff that is slip rolled since there is a space inbetween the center of each roll) this has to be sort of hand formed over a mandrel (a piece of pipe or round stock for me probably). A little bit of a learning curve getting these things rolled and putting my little harborfreight slip roll unit to use and actually making it form like it should.
    A frustrating component in the beginning was how the sections wanted to twist basically left and right as they were being rolled where the ends would not match up. Finally, I realized, if I rolled them against one far edge of the machine, it would sort of act like a guide as they went around and help keep them straight. Thats not a fool proof method, and the wider the section is, the worse it is (this may be partly due to the brilliant chi-com quality of the roller adjusters and alignment on this particular unit also). Basically, no matter how much you try and make them perfect, you still have to just grab them with your hands and twist/form them into submission and proper alignment.
    When it came to welding them, I basically put each section back in the slip roll, rotated to the seam on top. I then was able to take my left hand and kind of squeeze them together and make sure the edges were properly aligned and do a fusion tack weld with my tig welder to get them stuck together. I could then come back by and do a weld the rest of the way across the seam. Occasionally on very troublesome ones I would put a pair of vice grips on one edge and then tack the opposite while holding it together and that helped me out. The very final piece that tapers down to the stinger tube section was a royal to do because it was such a short piece, an abrupt taper, and its angle cut ends but I finally got it and it doesnt look half bad.
    So, still left to do is;
    #1: finish forming the edges and seams to round out.
    #2: Hit with belt sander to ensure all edges and sides are good and flat for perfect fitment.
    #3: Start stacking and working my way around the frame and chassis..
    I think I might try and do a little video tutorial with the stainless sections sometime - its an interesting process, a lot of variables, for sure. I would like to start working on snaking around this weekend. I have an issue with the water cooler on my welder and I'm almost out of Argon so I'm not sure I'll be able to get to it, but definitely gonna try.
    In the interim here is my old man, holding up his bounty from yesterdays efforts with me. (Not pictured is another "stringer" of sections that makes up the total amount)
  12. #222
    Live Oak, FL
    15,069
    I just realized this project will be A YEAR OLD soon....
    dear lord, where does the time go
  13. #223
    Live Oak, FL
    15,069
    Pipe has been slow going. I ran into some issues with my welder and had to replace some hoses on it, and then been tied up the last several weekends with other things. Old man and I worked on it some on Sunday, and got this done. I think my argon controller is fixing to go out on it also...
    I have serious concerns how I'm going to fit all of this in there, at the largest point the pipe is 6inches around. I might need to extend out the kick starter shaft, or something. This is till one of the smallest sections and areas, here.
    Some spring hangers I bent up out of 1/8in welding rod.
    And a little bit earlier, first coming off of the slip joint on the exhaust flange.
  14. #224
    ONEBAD350X's Avatar
    ONEBAD350X is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2008
    Iowa
    339
    superb welding and fab skills man! looks awesome!
    85 350X
    85 330R
    85 250R
    86 250R
    86 200X
    86 200X
    AVATAR IS MY OLD 350X
  15. #225
    tecaterob is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2008
    Miami Fl
    435
    Looking good!!!
    3 86 Tecate 3
    1 87 tecate 3 (with kx 540 motor)
    1 87 tecate 4 (with 330 motor, 250r geometry)
    1 83 atc 70
    1 Kfx 50
    1 kfx 400 ( with 470 parting out bike)
    1 78 KZ 1000 ( with 1340 turbo)
    1 Aprilia SXV 550 Supermoto
    1 01 ZRX 1200 prostreet (sold)
