Results 1 to 10 of 10
Thread: rebuild time
    Mar 2013
    New Hampshire
    83
    rebuild time
    I have a 1985 honda 200x the motor seized on me last night
    .,there was plenty of oil so I think I'll just rebuild every tClick image for larger version.
Name:	2013-09-10 10.44.34.jpg
ID:	177216Click image for larger version.
Name:	2013-09-10 10.44.23.jpg
ID:	177217hing. I know this will b a long project but I feel it's worth it. what do u sugjest for power adders. I know I need a new cylinder anClick image for larger version.
Name:	2013-09-10 10.44.13.jpg
ID:	177218d exhaust because some one gob welded it. this is pre tear down.
    Mar 2013
    Central PA
    2,362
    Bigger carb maybe, remove air box lid, bore your cylinder over. Not sure how much. Basically just upgrade internals from there.
    Mar 2013
    New Hampshire
    83
    so valves spring clutch Cam port and polish(don't know how much that'll give me. I think I wanna keep the look stock and make it a sleeper. it was already quick
    Mar 2013
    New Hampshire
    83
Name:	2013-09-14 21.28.27.jpg
ID:	177247 piston when I pulled itClick image for larger version.
Name:	2013-09-14 21.27.57.jpg
    6,783
    So what was seized on the motor ? Crank ?
    Mar 2013
    New Hampshire
    83
    when it happend if sounded like the piston seized in the cylinder when I disassembled it it started turning over fine I don't understand but I have a good sized gouge in the cylender alot of people I ask are saying it was to lean and that's what did it but it looks like the motor had metal beads in the cylinder I checked and there wasn't any. atleast it's a simple motor. I eaither need head work or a new head.
    Sep 2011
    New Castle, PA
    1,134
    Quote Originally Posted by cambroseispro View Post
    Valves arent cheap that are OEM. They were $40 a piece from my shop, but worth it.
    Valve springs, powroll may make them, but I cant remember
    clutch: keep your basket and pressure plate if they are in good shape, but get a barnett dirt digger clutch plate kit
    port and polish: lots of people do it, whether on here or a shop. not 100% sure
    cam: they're going to be kinda expensive, either a WEB cam or a powroll mid range cam would be good.
    other things:
    For the most power, go stroker
    Gone:
    Mar 2013
    New Hampshire
    83
    how much can you bore a 200x before the cylinder is to thin. only trike I owned before this was a Suzuki alt 125. I want more and IM trying to start a small engine shop. but anyways clutch basket and pressure plate is fine I just looked at them.
    Sep 2011
    New Castle, PA
    1,134
    A safe rebore is 66mm. I would say max is 66.5, and at 67 the base of the cylinder can break easily
    Gone:
    Mar 2013
    New Hampshire
    83
    How do u do timing on the 200x
